Author Subject: Smaller master cylinder?
marksorrento205
Is there a direct fit master cylinder, that has a smaller bore than the standard one, to fit the rallye and still keep the abs?
Posted 15th Mar 2011 at 19:27
Rich E Forum Admin
Yeah, there's a 22.2mm one used on the smaller engined cars with ABS that should be a direct fit.
Posted 15th Mar 2011 at 19:46
james_gti6
Saxo vts i think is the one you want, somebody correct me if im wrong
if i dont see you in the mattress il see you in the spring
Posted 15th Mar 2011 at 19:47
atterz
Dturbo one with abs, the pedal has a lot of travel on mine with 6 brakes on it mind!
owain wrote:
Posted 15th Mar 2011 at 19:55
RHD without abs will do as well, as they only run a 2 port M/C.
Posted 15th Mar 2011 at 23:23
tvrfan007
What are you up to that's got you thinking about downsizing master cylinders?
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 16th Mar 2011 at 01:00
more braking pressure maybe, or 4 pots with smaller pots overall than the original 57mm.
Posted 16th Mar 2011 at 01:33
tvrfan007
Must be, as the pedal will go to shit with the standard Lucas jobs. I wonder if he's going to Wilwoods.
We pinched 406 Brembos to fit on our Rovers as the spacing was just right to nestle in between the hub ears and the Rover shares a 23.8 bore master cylinder.
I'm Si btw Tee hee
Posted 16th Mar 2011 at 01:43
marksorrento205
Thanks for all the replys. Its just putting the feelers out really. Two things, as you have said 4 pots and also reduced pedal travel on the std 6 ones. Think I have got the latter one wrong though LOL
I hate the first part of the pedal travel you get when nothing happens. Brakes work really well and have been presure bled so its not air related. Can you adjust the servo output rod like you can on a 205?
Posted 17th Mar 2011 at 01:24
yeap Smile
Posted 17th Mar 2011 at 02:08
atterz
If you hate the dead travel on standard brakes dnt even bother with a smaller mc, my dtub has a Lot of travel before anything happens! Ask hanpug when I test drove the wallye, nearly put my head through the windscreen!
Posted 17th Mar 2011 at 17:37
