Author Subject: CV Boot Split
bezza90
Grrr, a piece of the inner wheel arch came off a bit(the bit which covers the Aux Drive belt area) and lodged in the wishbone and driveshaft.
I have now noticed there is a slight rip in the CV boot in one of the pleats about 1cm long, so it must have caught it when being forced down by the wheel/driveshaft.
Question is, how long would be considered safe to drive with it like that? I can probably get round to changing it on the weekend, but will not get round to it before. I still have to drive to work every day until then, which is 35 miles round trip of mostly motorway.
Am I ok to leave it until then?
'00 Astor Grey GTi-6
Team: 'EVO Triangle'
This is a quantum car. I don't know where I am, but I'm going really fast.
PS3 ID: Skaankypuppy
Normally play GT6
Posted 15th Mar 2011 at 00:52
Rich E Forum Admin
I wouldn't leave it, it will splatter grease everywhere if you do.
Clean the area carefully and put some strong oil & grease resistant tape over it if you absolutely need to drive the car until the weekend.
Posted 15th Mar 2011 at 00:56
bezza90
Ah bugger, I was hoping it would be Ok until then. Would Gaffer tape be ok do you think? I think my parents have some, otherwise I think I only have Cellotape!
Normally play GT6
Posted 15th Mar 2011 at 01:34
smegal
It isn't that big an issue but as Rich said it sprays grease everywhere, and the longer you leave it the more chance of it knocking in the future.
Ex SC-6
Now in a Megane R26
Posted 15th Mar 2011 at 01:50
bezza90
I have just spoken to pug about the cv boot kit and he says it is £18.80 including VAT. Does that sound right? It should be there in a couple of days.
Normally play GT6
Posted 15th Mar 2011 at 22:06
check with GSF, they do o.e quality Corrteco and GKN off the shelf Thumbs up
Posted 15th Mar 2011 at 23:17
bezza90
I am in the proces of removing the driveshaft, do any of you guys know what I am missing it getting the drivers side shaft out of the gearbox, it does not seem to want to just pull out?
Help thread here help thread
Normally play GT6
Posted 20th Mar 2011 at 19:20
Rich E Forum Admin
The mid-shaft bearing can seize into the lower engine mount housing.
Make sure you've fully loosened off the pinch bolts and rotated the head out of the way and put some force on the shaft from the inside of the mount if it won't move.
Removing the speedometer drive housing isn't essential but it does make it easier to withdraw the shaft.
Photo of the mid-shaft bearing pinch bolts from the cutch / gearbox FAQ:
Posted 20th Mar 2011 at 20:53
as above, loosen the nuts but dont remove them, push then rotate 180 degrees, then smack the collar on the shaft that sits next to the intermediate bearing.
Posted 20th Mar 2011 at 21:02
bezza90
Cool appreciate your help gent's. I have given up for today, so the car is going to stay on axle stands until tomorrow. I hate it not quite knowing the best way, but I suppose until you try these things you don't know.
I am planning on finishing work a bit early tomorrow to finish it off.
The other problem I am having doing it on the car are those bloody clips for the CV boot. I bought one of the hose clip tools to do them but cannot get enough force to even get it close to clipping over the lip (on the small one - I haven't even got round to the large one yet, but should imagine it would be a tiny bit easier).
In addition to that, whacking the CV joint back over that metal ring on the spline is also proving to be a nightmare!
I should think once I get the driveshaft off it should be a bit easier, as I can clamp it, as currently I am whacking it and there is a bit of recoil in the driveshaft, taking away the impact force. Is there any better way to get that on, or is it just a case of brute force and ignorance?
Hopefully I can get a bit more armed with techniques so I can nail it tomorrow in a few hours before the light goes, as I could really do with having the car working!
Normally play GT6
Posted 21st Mar 2011 at 00:00
