Author Subject: Rear suspension sagging
cornish_pug
Hi
I've noticed recently that on the rear the drivers side suspension sits lower than the passenger side. I've had the car 5 months and it's been like it since i've owned it. I've noticed that there has been rubbing on the arch liners on both sides.
Could it be that it's been lowered before and not been done properly?
Could it be a damper on it's last legs?
Thanks
Team Diesel
Posted 14th Mar 2011 at 05:15
Won't be the damper, as they don't set the height.
Could be that it's been lowered badly yes, could be a worn torsion bar end that's spun.
How much lower is the one side than the other? It's not unusual for the two sides to be out by 10mm or so. Bear in mind uneven ground makes a big difference, so get all wheels on a perfectly flat surface and measure your arch heights Yes
Posted 14th Mar 2011 at 12:57
jonnie205
collapsed trailing arm bearings
Posted 14th Mar 2011 at 14:41
cornish_pug
Thanks for your replies Smile i'll put it on flat ground & i'll measure up.
Then i'll get back to you.
Team Diesel
Posted 14th Mar 2011 at 14:57
storm-photographique
Same as, the drivers rear wheel sits further in the arch than the passenger side. Yet another problem to fix on my 6
Phase 2 Blaze GTi-6 ex left hander
Posted 14th Apr 2011 at 21:57
donald ducked beam, time for a replacement unit.
Posted 14th Apr 2011 at 22:06
cornish_pug
I've measured the height on both sides on level ground & the offside (driver) sits 15mm lower than the nearside (passenger) Mellow.
Team Diesel
Posted 15th Apr 2011 at 03:52
