Author Subject: ph1 door car removal
noaki
how the hell do ph1 door cars come off i have used the FAQ but its a broken link or just takes me to page 2 of the faq ..little help?
Team ex "manstone" - "THATS TO LOW!!"..."I KNOW!" Sad
Team defeat - bring on the *06! :/
Posted 12th Mar 2011 at 01:29
mjstones
there's a couple of star bit bolts, should just pop off after that.
Never underestimate the power of De-Nile.
Friday afternoon car, built in France.... Ninja
306gti6.com Stickers available, pm me for details. or email MjStones83@hotmail.com
Sticker Thread with pics
Posted 12th Mar 2011 at 02:18
noaki
where??? :haha
Posted 12th Mar 2011 at 02:41
sixysix
Three nuts in the grab handle/arm rest (10mm) iirc
Obviously remove switches, door handle surround, and door lock pin.
Then there will be a few screws along the bottom edge of the door card.
Then just pull gently to release poppers.
You may need to give the grab handle a bit of a tug as it's a tight fitting at the front nut/bolt
Smile
Take a look
Posted 12th Mar 2011 at 02:46
dan_s16
Putting the door lock pin back on will cause lots of swear words, they are the stupidest design ever! I've given up trying to get my passenger side one to stay on
Posted 12th Mar 2011 at 08:40
noaki
Ok thanks for the pointers time to start swearing alot at that car I don't want want on my drive lol
Posted 12th Mar 2011 at 11:03
davidmartin
Internall mirror covers just pop off as does the top bolt cover,door handle surround you prise off with a knife starting at the top right corner ,Be carefull as you prise off the speaker cpvers as they break easily,pop off the door lock pin,the top bolt in the arm rest that was under the cover is a ten mil socket and the two lower ones are 8 mil,undo the speaker screws and unplug the speaker also the screws in the card compartments, then pop the card off and lift out of the top channel.ther is a little difference in the earlier cards so dont panic if you cant find any of the screws I've mentioned.
pet hate, the cat
Posted 12th Mar 2011 at 12:45
sixysix
When I first did this, it took me ages to put it back on right, but it's really very simple, for a phase 1 anyway.
Get the door pin, then with a tiny screwdriver, push the tab in through the hole and position the inner slide so it's in the lowest position.
With the door card back in place, open the window, close the door and lock the car, then push the pin into position and press down hard.
It will locate and grip the metal rod and stay in position when locking/unlocking manually or with the CL Wink
And yes, I forgot about the speaker covers, mirror covers and the three bolts holding the speakers in, should be pretty obvious though LOL
Take a look
Posted 13th Mar 2011 at 00:29
dan_s16
Oh i've done exactly that hundreds of times, I think the little clip is knackered on mine and not holding it properly any more. When I can be bothered I may go and see if I can get some new ones from peugeot but as it's the passenger side that plays up it's not on top of the list to sort out
Posted 13th Mar 2011 at 00:42
sixysix
I thought you would know but just in case LOL
Probably the plastic that grips has worn down too much Smile
Take a look
Posted 13th Mar 2011 at 03:14
cwspellowe
Lock pins? Pfft, my door cards have been off that many times they won't pop back into place any more, never mind the little fiddly bits! LOL
Bye bye Sundance Kid Sad
Posted 13th Mar 2011 at 17:10
noaki
right got the door cord hanging on the window switches but cant get the back of them to unplug them how the heck dose the switch box come off / out managed to pill hte face off it tho :/
Posted 13th Mar 2011 at 19:46
davidmartin
Just prise them out,unclip the plugs and push the wires through.
pet hate, the cat
Posted 14th Mar 2011 at 00:11
sixysix
Shall we just break the car for you Whistle LOL
Take a look
Posted 14th Mar 2011 at 00:36
