displaying posts 1 to 2 of 2
Author Subject: Phase 3 starting problem
dan2315
right i have had no problems starting the engine before untill today, i removed the drivers seat to get to the central locking box, i removed it to see if it was ok, (reason is because central locking dont work and have a new drivers door with a different key) so i put everything back together, tried starting the car and it will only keep turning over but wont start as if there is no petrol in it, and suggestions????
Posted 9th Mar 2011 at 03:50
pugjim
Check the terminals on the connector on top of the fuel pump, maybe you have knocked that while fiddling around? sometimes they get a bit of corrosion on them and cause bad connection.
Posted 9th Mar 2011 at 22:17
