Author Subject: VDO Oil pressure gauge
I have a VDO oil pressure sender and a VDO oil pressure gauge, both are 0-10 bar items.
I have searched on here and google and failed to find out whether theres any particular wire thickness that i should use for the signal wire, i was thinking that 0.5mm would be sufficient, but wasnt sure whether this would affect the signal. Dunno
The gauge itself has three posts, one +, one -, and one S.
The gauge didnt come with any instructions so if anyone in the know could confirm that - should just be earth, + should be to a switched live and S should be to the G on the pressure sender?
Also, theres a couple of spade connectors on a black thing on the back of the gauge, i think this must be for the backlight, but would like confirmation before i wire it all up and possibly damage something Laugh
Thanks in advance for any help Smile
Posted 9th Mar 2011 at 03:46
james_gti6
the two on the left are illumination, doesn't matter which way they go around, yeh 12v ignition feed, a earth and a single wire to the sender, im guessing it earth through the block. normal 14/0.9 strand cable will be fine for the the signal wire.
if i dont see you in the mattress il see you in the spring
Posted 9th Mar 2011 at 04:06
Thanks Thumbs up
Posted 9th Mar 2011 at 11:44
anth
I used 5amp from memory
Posted 9th Mar 2011 at 16:57
