Author Subject: Holding revs
mikekean
Hi, My 306 rallye holds revs when changin gears. It seems to hold at 3k and then takes a couple of seconds to go back to idle which IMO is not right. Do gti-6 engines just do this or do i have a problem?
Posted 9th Mar 2011 at 00:06
Im pretty sure mine did this when my icv was going on some occasions. Might be a good starting point
Posted 9th Mar 2011 at 00:36
lewisdmz
What car did you have before?
I was sure my 6 had a problem when i first got it as the revs seemed to hang a lot when changing gears. It was just my right foot though as I had driven diesels for 2 years and gotten used to the complete lack of throttle response.
Posted 9th Mar 2011 at 00:40
mikekean
Got a 106 rallye aswell, its not my foot as I thought that at first but i made a thing of taking my foot right off the throttle when changing gear and it still does it.
Posted 9th Mar 2011 at 01:06
toddy
You have a slight air leak on the inlet side, trace and rectify.
Posted 9th Mar 2011 at 02:45
ahhh yeah actually hes right^ i had that at the same time asw the icv and the pipe detaches from the intake so its probably that
Posted 9th Mar 2011 at 06:18
mikekean
Ok cheers for the replies, Ill go check for leaks tomorrow.
Posted 9th Mar 2011 at 06:19
darzmat
glad i read this, mine does the same, where exactly do i have to look?? ayet another job to add to my ever growing list to do on my week off next week Sad
Posted 9th Mar 2011 at 06:41
mikekean
Basically any hose or gasket the goes onto the inlet manifold between the throttle body and the head that could let in air.
Posted 9th Mar 2011 at 07:10
oecken
Just about to say this, after spending a discusting amount of money (basically checking everything else) turned out to be cracks that had got worse in two of the rubber pipes, replaced and the car had never run so quite / so smooth / and idled lower, must of been then since i bought it just gradually got worse.
Posted 9th Mar 2011 at 13:19
mikekean
Had a poke round with the car today, checked all the pipes I could find for cracks etc and they all look perfect no signs of cracking etc. I cleaned out the throttle body and ICV. I also took the ICV apart and sealed with some silicone incase the oring had gone hard and started letting air in.
I took the vacum take off for the servo on the inlet off and blocked up the nipple to eliminate any of the servo pipes being the problem and the it still held revs, apart from the servo take off, ICV, fuel rail vacum, and the EGR take off is there anywhere else air could be getting in?
Ive resett the ECU and it helped for about a minute then the problem came back. Im thinking its the TPS rather than an air leak if im honest.
Posted 10th Mar 2011 at 01:44
Rich E Forum Admin
My money would be on the ICV starting to pack up.
It could possibly be the TPS too.
Posted 10th Mar 2011 at 01:54
mikekean
Would either the TPS or ICV throw up a fault code on the ECU if they were faulty? might take it to my mates garage to get it plugged in.
Posted 10th Mar 2011 at 01:59
Rich E Forum Admin
Possibly, but it may just show as a mixture control issue.
Posted 10th Mar 2011 at 02:06
oecken
unfortunatly as above it could be quite a few things, see my thread for similar answers, ICV was out, cleaned, checked. as well as everything else took the best part of £200 for eccosse to bend me over and fix it, bad times.
Posted 10th Mar 2011 at 05:49
