mikekean wrote:Gonna try some tappet treatment in it anyway
I really wouldnt bother, get it to a decent mechanic and explain what the common issues are with these engines.
Namely fook all valve to piston clearance, plus very large valve heads which can clash against each other if the cams are turned independently, and due to their size they protrude out of the combustion chamber with the cams pinned so if the head was laid face down they can bend this way too (only 6mm stems IIRC)
Also lower bely pulley's outer section can slip when the rubber deteriorates, the pin hole is in the outer section
(not an issue if whoever takes it apart pins it up properly beforehand...)
need a part number? get on here -
http://public.servicebox.peugeot.com
