Author Subject: Speedo Needle Twitching
bennn
When i start my 6 the rev counter doesnt work (doesnt move off zero) for the first 10 seconds or so then works as normal. Also when i switch it off the speedo needle twitches around zero very quickly and makes a slight clicking sound.
Ive had no issues with the speedo not working and the rev counter works fine after about ten seconds when its flicked off zero.
Cherry Red 306 HDI
Posted 7th Mar 2011 at 18:41
smegal
Check your battery voltage and earths.
Ex SC-6
Now in a Megane R26
Posted 7th Mar 2011 at 21:12
bennn
Cheers for reply.
How can i check the voltage and wherabouts are the earths?
Cherry Red 306 HDI
Posted 7th Mar 2011 at 21:16
gti-gaz
Mine does this too although I didnt think it was anything to worry about..
I will admit however the speed stopped working the other day Shock
Posted 16th Mar 2011 at 20:56
bennn
If it stops working its probs the speedo drive cog that sits in the gearbox.
Mine has never not worked, just twitches after you switch off the ignition...wierd
Cherry Red 306 HDI
Posted 16th Mar 2011 at 20:59
swiftyboi006
Sounds like a slight power surge so yea check voltage and earths
Black p3 Love
Posted 15th Apr 2011 at 02:42
bennn
Its now had a new battery as the old one was knackered, no change. I asked Carl about it when it was having a cambelt and he said it was most likely a fault with the clocks. Ive just got used to it now.
Cherry Red 306 HDI
Posted 15th Apr 2011 at 03:00
