Author Subject: ITB's
mark t
Couple of quick questions. What sort of gains can be expected from running ITB's on a standard engine and has anyone here fitted bike ITB's before? Are cams required to really make a difference and what can you run before taking the engine appart?
Sorry for the daft questions
Mark
Posted 6th Mar 2011 at 22:30
mark t
Just read Kent PT81's are close to the limit on the cam front, are they a regrind or from a blank and are solid lifters/double valve springs required?
Posted 6th Mar 2011 at 22:37
pugjim
I built an engine with piper 270 regrinds, a bit of head porting, fully balanced bottom end and lightened flywheel, cosworth green injectors, jenvey 45 TB's and port matched jenvey/longmann manifold and saw 215bhp at flywheel on dyno.
Posted 7th Mar 2011 at 00:25
mark t
Good results, who did you get your Jenveys from?
Posted 7th Mar 2011 at 00:26
pugjim
Direct from jenvey, think they were about £360
Posted 7th Mar 2011 at 00:28
mark t
Standard ecu remapped? and did that include the manifold?
Posted 7th Mar 2011 at 00:29
For comparison I had Jenvey 45s on a completely standard engine, with a S/Steel exhaust and a decat and I got 179.
mark t
Really? what's standard again 167?
Posted 7th Mar 2011 at 00:31
pugjim
That was a DTA E48 ecu, manifold was about £120. Also it is in a 205 GTi (not like that should make a difference)
rallyeash
yep, generally standard tb'd engines turn out 185hp
309 3dr K20 Type R
Posted 7th Mar 2011 at 00:33
12-14 years ago, before a a few thousand miles of accumulated wear and neglect yeah Wink
Steer clear of solid lifters unless you are going for high rpm and radical cams. The valve springs are doubles as standard. However if you want to set any kind of performance cam correctly you need to pocket the pistons for safety, it's just too close to take a chance, especially if the head has ever had a skim.
Posted 7th Mar 2011 at 00:36
maddriver9
my mate has weber throttle bodies and omex doing 186 bhp but my standard 6, well just an air filter and decat made 178 bhp on the same rollers.
178bhp 205gti6
¼ mile in 14.2
Posted 7th Mar 2011 at 00:41
mark t
By the sounds of things it is best to either not go with camshafts at all or something very mild ie regrinds. Also read that the standard heads cant be improved upon. ITB's don't seem to have much bang per buck either.
Prob best to concentrate on suspension and brakes lol
Posted 7th Mar 2011 at 00:42
ryangti6
It's not that the standard head cant be improved it's more of a case that it flows well enough to get the power most will be chasing so no real gain to be had.
I've never been in a cammed one but power for money doesnt seem like it would be worth it to me tbh and it doesnt seem like there is much point in Itb's without cams.
You are right that it's probably best to concentrate on suspension and brakes etc but again unless you want to spend a lot of money I would go for new o.e parts. Good condition standard items are more than good enough for a car with standard power unless you are looking to do track work. It's the balance these cars have as standard that make them great Imo
Ryan
Posted 7th Mar 2011 at 01:18
mark t
Some fair points there, just out of interest (I know its the wrong section but cant see any point starting a new thread lol) are the front struts an outer casing with a replaceable insert?
Posted 7th Mar 2011 at 01:23
pugjim
nope
Posted 7th Mar 2011 at 01:31
mark t
Cool, thanks
Posted 7th Mar 2011 at 01:36
