Author Subject: Block sensors
tvrfan007
Hi gents,
Bear with me as i'm newish to these engines. What are the sensors on the block?
The one I labelled C is in fact connected to the purple spade terminal to the right of the pipe.
The one I have labelled M16 blank, is this one of the two positions I read about that you can fit an aftermarket oil pressure gauge?
It's from a Phase 2 Xsara VTS if it helps. Your input is appreciated. Smile
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 6th Mar 2011 at 21:29
tvrfan007
Nobody? Razz Just curious Wink
I'm Si btw Tee hee
Posted 9th Mar 2011 at 01:27
Rich E Forum Admin
A - Oil warning light pressure switch
B - Knock sensor (late type - Xsara only for this enigine)
C - Oil level probe
D - Knock sensor (early type - only one used on the 306)
Blank - Unused on the Xsara - Phase 1 GTi-6 oil pressure gauge sender
Follow the cable on the D connector and see where it goes. You shouldn't have both connectors there. The early knock sensor had a tail out to the connector and as you can see the later one has the plug on the sensor body.
Posted 9th Mar 2011 at 02:07
tvrfan007
D goes as you describe, to a sensor in the block front, right behind the black plate, you can just see the gold coloured head of the bolt at the top centre of the photo.
That's a bit strange, it came from an 02 Xsara, and seeing as I was guaranteed to have plugs spare when dropping the lump in my rallye i was just looking to see whether they were required.
Thank you for your help Rich, by chance do you work for Pug? Smile
I'm Si btw Tee hee
Posted 10th Mar 2011 at 01:55
