Author Subject: dam brembos
teo79
Ok ive got a set of 406 brembos for my 6 a long with xantia v6 discs ive been told they would fit so i did a test fit and the front of the disc touches the inside of the caliper how do you get these discs to work with the calipers there must be a way
tjones
Posted 6th Mar 2011 at 19:23
Rich E Forum Admin
288mm Xantia discs are a direct fitment with 406 Brembo calipers on the 306 Yes
Do you have the make and part number of the discs?
Posted 6th Mar 2011 at 19:35
teo79
I bought drilled and groved xantia v6 discs months ago off ebay i dont have a part number with them they touch and lock up when the caliper is bolted up
tjones
Posted 6th Mar 2011 at 19:54
As Rich says, 288mm is what you're after, measure them up and see what you've got.
Almost certainly though you have the wrong discs.
Posted 6th Mar 2011 at 20:01
teo79
Ok ill measure up tomorrow cheers
tjones
Posted 6th Mar 2011 at 20:20
bellcp306td
There not direct fit. You will have to mill some off the brembos. Or you can use 307 HDI 110 front disks which is direct fit but they squeal.
Where did the road go!
Posted 8th Mar 2011 at 01:57
Rich E Forum Admin
The 288x28 discs are a direct fit.
There is also a 283x26 disc used on the Xantia that does not fit directly. It sounds like you (and the OP) have / had those.
You can see on the drawings that there's a 4mm difference in the mounting face to disc face offset.
288x28: 283x26:
And this is the 206 / 207 / 307 283x26 disc:
Posted 8th Mar 2011 at 05:36
Erm.. yeah I was about to post up those pics I had to hand too LOL
I guarantee the Xantia 288x28mm discs are a direct fit, because I fitted them directly.
Posted 8th Mar 2011 at 12:39
teo79
brembos went on for 12 months came off back to standard the end
tjones
Posted 26th Jun 2012 at 18:08
ed_doe
^ Did they just squeal too much then??
'97 Black Dturbo 110,000miles: SOLD
'99 Ph3 Diablo Gti6 108k RIP
'93 106 1.5n/a d: daily hack YAAAAAWN
'00 Ph3 Astor GTi6 117k Love
Posted 8th Jul 2012 at 15:03
