Author Subject: Some supercharger questions
felixthecat
My supercharged engine will be finished soon, just need a few things to know before i can start Smile
Do i need NGK Iridium spark plugs on low boost engine? If yes, whats the exact part number?
What is the best oil to use (only road, use not going on track)? Car will be only driven in summer.
Anything else than royal purple, something that is availaible in germany, too. And wich grade should it have?
Supercharger has a run in period of 60 miles. Is it ok to drive with 95 or 98 octane petrol if i rev it to only 3k? After the run in period i'll use Shell V-Power.
Thanks guys for help.
306 Gti6 Cherry Red Supercharged Smile
Greets from Germany....
Posted 1st Mar 2011 at 23:31
cosmic spanner
Moral objector
Pics of the project/conversion?! Happy
Doesn't need to be NGK Iridium specifically, just good quality plugs. The important part is that they are one or two heat ranges colder. I run BKR7EIX, I know several other people do too.
As for engine oil, is this low boost or high boost? For high boost I would probably stick to Royal Purple or whatever Rich W recommends, but it is very expensive. For low boost I have had no problems running a good quality fully synth i.e. I run Mobil 1 0w40 and have done on a couple of trackdays, but then I have good oil cooling courtesy of Laminova. I would suggest Silkolene/Fuchs Pro S 10W50.
Hope this helps Thumbs up
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 1st Mar 2011 at 23:44
davedgti6
I think you use a grade 7 plugs for the low boost supercharger (as above) -which is one grade cooler than standard, -don't use standard o.e plugs they can get too hot and pre-ignite cause knock and destroy your engine, I would use the Iridium ones, they are cheap enough on e-bay,
I use Royal purple oil but if that's unavailable/too expensive I have used Mobil 15W50 when I was low boost,
Use high octane fuel only i.e super unleaded or Vpower,
and enjoy the supercharger conversion, it makes the car such a pleasure to drive Smile
Posted 2nd Mar 2011 at 00:33
mcfc1987
also make sure you have an upgraded crank pulley! mine failed rather spectacularly!
Posted 2nd Mar 2011 at 00:12
smegal
I would recommend PRO-S oil
Reasonably cheap here
Ex SC-6
Now in a Megane R26
Posted 2nd Mar 2011 at 00:36
ballardpaul
What's the need for using 95ron petrol just for the 60 mile run in period? Not worth the risk is it...
Nissan 350Z (300 BHP)
Posted 2nd Mar 2011 at 00:39
smegal
I'd only run it on super unleaded.
You REALLY don't want to be f*cking your engine up for the sake of a few quid.
Ex SC-6
Now in a Megane R26
Posted 2nd Mar 2011 at 01:25
felixthecat
Already have one Big grin
Thanks guys so much for all the replies Thumbs up
I will then go for the NGK iridium plugs and run always with high octane fuel as i dont want to risk any damage.
I'm going to take many pics during the conversion and will upload them in the project section Smile
Think i will be the first guy from germany who have a supercharger in his 6....feels good LOL
Posted 2nd Mar 2011 at 02:23
smegal
Enjoy it!
Fuchs TITAN PRO-S is what I am using in mine.
Ex SC-6
Now in a Megane R26
Posted 2nd Mar 2011 at 04:05
rich_w
Felix,
You want the NGK BKR7EIX spark plugs.
You should always use a high octane fuel, the higher the better. The issue is the engine has a high static compression ratio, and couple with boost means very high peak cylinder pressures. The high pressure and associated heat encourage detonation (where the air fuel burns uncontrollably) which is fatal for any engine.
Higher octane fuels burn more controllably /slowly at higher temperatures and pressures, meaning the air fuel mix burns steadily with a nice even flame front moving from the inlet to the exhaust side of the combustion chamber.
As for oil, we recommend Royal Purple XPR51 which is a 20W50 fully synthetic. Avoid low viscosity oils as these generally offer low oil film strength when hot.
Good luck and enjoy Wink
Contact Details:
07732 822546
Posted 2nd Mar 2011 at 14:27
russbez
get pictures up
and have fun Cheers
My Rallye project thread
Posted 2nd Mar 2011 at 14:38
felixthecat
Thanks Rich for your comment!
Just ordered the NGK iridium plugs and a can of Mobil 1 Formula 15W50
Posted 3rd Mar 2011 at 03:07
icetto
Goodluck with the conversion.
Use the higher octane fuel from the start.
What supercharger are you gonna use?
Jy dink jys cooler as ekke
Posted 7th Mar 2011 at 12:32
monkgti
sorry to hijack your thread, but would it be possible to add octane booster to the fuel to use in the S/C conversion? The problem over here is nearly every station bar Maxol just have 95ron, Maxol has the E5 which is 99ron, but the closest Maxol to where i live is a little over 20miles away
IF YOU CAN READ THIS IM STILL IN 5TH!!!
Posted 7th Mar 2011 at 19:10
