Author Subject: stalling at lights
1.6306
hi im having troubles with engine hunt, not all the time but when the weather is cold it happens more often, the needle always moves up and down slightly, but when i come to a stop the revs will just drop so fast and low that the engine goes to stall and then other times it will catch the reves at it should, ive changed the iacv, map, tps, fuel filter, air filter, spark plugs, cleaned intake manifold, all breather pipes, and new coolant,
i have attached a video of the revs when they go funny its not the best video as it didnt catch it when its bad but this is wat happens evrytime i stop.
http://www.youtube.com/watch?v=2DAAYCxD_s8
thanks in advanve for any answers
Posted 1st Mar 2011 at 18:23
l_e_cook
i had that problem recently i took the plunge and got robbed by peugeot to have it plugged in and found out the *new* icv was buggered maybe no help but it runs sweet again now
Posted 2nd Mar 2011 at 01:04
1.6306
did you have a check engine light on to be able to pull of the codes? thanks for the reply
Posted 2nd Mar 2011 at 04:26
