Author Subject: nimrods over brembos
eddy_gti6
my mate has a 106 gti with brembos on and he is running cyclones on 20mm spacers, was wondering would he still need to use 20mm spacers with nimrods?
Posted 1st Mar 2011 at 03:41
bennn
Would have thought he might need bigger spacers if they would fit at all.
Think you are meant to put spacers on 206 alloys if fitting to a 106 / 306 as the offset is different on the 206.
Cherry Red 306 HDI
Posted 1st Mar 2011 at 15:01
Lecktorious
aka G.
You'd need spacers running Nimrods, 206 offset is ET25-28.
'98 Nile Blue 306 GTi 6
Posted 1st Mar 2011 at 16:04
aknight
Wifes old 406 SRi needed 13mm spacers to clear Brembo with 305mm dics with her 16" nimrods, hope this helps.Big grin
Team 330mm.Team Rallye.
Posted 1st Mar 2011 at 17:39
jardo
Unless you got 406 Nimrods which are ET20.
Posted 2nd Mar 2011 at 00:02
eddy_gti6
there off a 206 the nimrods he will be getting i think? 16" ones. not sure yet. will have to see him 1st
Posted 2nd Mar 2011 at 00:43
bellcp306td
You will need 15mm spacers
Where did the road go!
Posted 13th Apr 2011 at 15:26
not really as the 305mm 306 discs are near zero offset, whereas the 288mm C5/Xantia discs required for a 106/306/205 arrangement with the same caliper has more offset, so may need less spacer, though due to the lower radius from the hub centreline may need much more!
Posted 13th Apr 2011 at 16:17
