Black Ph1 XSi-6161.8BHP (Getting Better!!!!)
| Author | Subject: P bush replacement |
:: blade ::
Senior User Location: Altrincham Registered: 21 Aug 2007 Posts: 697 Status: Offline |
Hi all, both ball joints and p bushes have gone on my pug, only 6months old or so, so abit miffed but thought i would just reaplace the balljoint and p bushes instead of replaceing the whole wishbone, what i need to know is, how easy is it to replace the p bush?? Ive done a search but couldnt find anythingCheers ![]() ________________________________________ Black Ph1 XSi-6161.8BHP (Getting Better!!!!) |
Rich E
What did you search for? Soup recipes or something? There are several useful threads and an FAQ, all locatable with the search function. P bush replacement FAQ They are probably wearing out because you've lowered the car so much. Fitting new P bushes at an angle so they sit flat when the car's on the ground will help the wear rate. The ball joints are very easy with the wishbone off, but if you have cheap wishbones you may find you need to drill rivets out. Remember you get what you pay for with suspension components though. Put cheap stuff on and you'll be back under the car sooner than you want to be. You may want to check your droplinks while you're in the area as they wear quickly on lowered cars too. ________________________________________ Rich |
:: blade ::
Cheers mate, checked the droplinks and there still stiff, is there any difference between the metal or plastic droplinks?? Ive got the plastic ones at the mo,Cheers ________________________________________ Black Ph1 XSi-6161.8BHP (Getting Better!!!!) |
mark.evs
Senior User Location: Near Bridgend Registered: 21 Dec 2010 Posts: 527 Status: Offline |
I found plastic ones snap easier, might be my driving style tho, I managed to kill one link in less than a 24hours! Apparanty the metal ones can bend but i've tried and tried and they're still fine. DONT use 1 plastic and 1 metal, it upsets the handling.Also dont buy cheapy bushes cos u'll be doing them in 6 months time too. Go for some OE ones like firstline or Quintin Hazel. cheapish and they last longer. ________________________________________ My GTi6 track projectWhite Rallye project |
:: blade ::
Ok cheers ![]() ________________________________________ Black Ph1 XSi-6161.8BHP (Getting Better!!!!) |
