Author Subject: overheating
kingbruv
have a strange problem with my 306 gti 6 when i drive the temperature is fine but when i have stopped in traffic or parked it overheats into the red but as soon as i start to drive again it cools back down and is fine. can anyone help please? (have replaced all sensors)
Posted 26th Feb 2011 at 02:28
smegal
Do the fans come on when you unplug the brown sensor on the thermostat housing?
Ex SC-6
Now in a Megane R26
Posted 26th Feb 2011 at 02:50
kingbruv
yea unplugged it and they came on
Posted 26th Feb 2011 at 03:03
smegal
Hmm search for "bitron" and see what comes up.
Ex SC-6
Now in a Megane R26
Posted 26th Feb 2011 at 03:20
honestly3k
I had this problem but it never went into the red.
Make sure when you are sat in traffic to put the blowers on hot and on max speed and to the top setting (front demister) and this will take some of the heat away from the engine.
My problem was lazy fan motors. They are both supposed to cut in at 97 degrees on slow speed and then switch off again at 90.
You need to run a little test and see if they kick in when they are supposed to. Once it gets to just above 97 degrees and if they havent kicked in give them a little tap with your finger to see if they then start rotating.
If they only come on with you physically tapping them then it sounds like lazy fan motors and you will need new fans.
It its not that then it could be a host of other things.
Posted 26th Feb 2011 at 03:22
kingbruv
ok cheers do i search in goggle for it sorry a bit clueless lol and ok will try this tomoz it only happens some times but when it does it gets really hot
Posted 26th Feb 2011 at 03:29
rallyeash
nah the search in the top right of this site budSmile
309 3dr K20 Type R
honestly3k
It it only happens sometimes then it could be the fan motors on the way out as sometimes they will work and others not.
Just start her up 2mora and let her idle to 97 deg water temp. Then repeat test over and over and see what happens....
Posted 26th Feb 2011 at 03:34
kingbruv
ok will try this tomoz and let you know wat happens thank you
Posted 26th Feb 2011 at 03:41
kingbruv
done test the fans work everytime but do not go fast when it starts to get hot any ideas
Posted 26th Feb 2011 at 17:46
honestly3k
What do you mean? At 97 they should both come on at LOW speed then go off again at 90.
Its only when the water temp reaches 107 that both fans should come on at HIGH speed iirc.
Posted 26th Feb 2011 at 17:49
kingbruv
sometimes it goes to red but they still stay slow. but doesnt always go into the red
Posted 26th Feb 2011 at 18:04
honestly3k
Sounds like it could be your relays.
Take the grill off and open up the triangular shaped box which has 3 relays in it. (just above the fans themselves)
Check relays for corrosion and clean them up
Posted 26th Feb 2011 at 18:23
mjstones
does the heater work?
Never underestimate the power of De-Nile.
Friday afternoon car, built in France.... Ninja
306gti6.com Stickers available, pm me for details. or email MjStones83@hotmail.com
Sticker Thread with pics
Posted 26th Feb 2011 at 21:25
kingbruv
yea heater works
Posted 26th Feb 2011 at 22:00
mjstones
ah, i had a similar problem but the heater didn't work either and that was the thermostat.
Posted 26th Feb 2011 at 22:16
kingbruv
got new relays put them in seems to be fine now hope theres no more problem now lol many thanks all :-)
Posted 27th Feb 2011 at 19:39
Demograffix.com
this thread is very useful as im having the same problem, i will check the relays and for a lazy fan motor
stevenage black gti 6, 198bhp
Posted 3rd Oct 2011 at 20:27
