| Author | Subject: Fuses |
mcfc1987
Seasoned Pro Location: lincoln Registered: 13 May 2008 Posts: 1,478 Status: Offline |
could someone please take me a photo of the fuse box near the battery. I'm missing what i think is fuse 33 which i think has something to do with the fans. my fans play up so i was hoping i have found the problem ________________________________________ |
mcfc1987
Mine looks like this![]() ________________________________________ |
mcfc1987
Balls, just seen the FAQ and the missing fuse is a diesel one________________________________________ |
smegal
When are they playing up?Do they come on when you unplug the brown plug? ________________________________________ Ex SC-6Now in a Megane R26 |
mcfc1987
they come on at about 77 degress along with the stop light, unplug the brown sensor and the stop light goes off and the fans kick to high speed.the sensor was replaced bit that didn't solve anything. only used to do it in wet weather, did it all winter but has kept on doing it. must be a dodgy wire somewhere ________________________________________ |
tvrfan007
Seasoned Pro Location: In the garage Registered: 29 May 2005 Posts: 3,488 Status: Offline |
For what it's worth, check the plug to the fan housing. As you look from the front, it's bottom, rear, right. It's prone to causing this sort of grief, self running fans, flashing stop lights etc.Worth a check, the pins might need a clean up. ________________________________________ I'm Si btw![]() Night Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
