Author Subject: Engine knocking
ben306
Well after my little rant yesterday
clicky
We've done some checks and it looks like sods law has kicked in. The bottom end seems to be knocking under load now.
Everything seemed fine on prior to the head gasket issues so it just seems my luck is out at the minute. The gasket failed in the 1st cylinder (Cambelt end) and the knocking is from the last (Flywheel end). When you unplug the coilpack from the last cylinder, the knocking goes, obviously its no longer under load.
So, is it possible to do any of the bottom end bearings from the sump side? Or is the only way to do it via removing the head again!!!
To say owning a french car is a love hate relationship is an understatement, still its done well to last so long with the abuse its had over the past 5 years.
My 306 Rallye Project Thread
Lap of Anglesey Coastal
3 sisters circuit
Few laps at Blyton
Posted 23rd Feb 2011 at 19:24
ben306
No one? Any ideas what can be done, if anything from the sump end?
3 sisters circuit
Few laps at Blyton
Posted 23rd Feb 2011 at 19:25
rich_w
You can change it all from underneath, no need to remove the head.
The only circumstances in which you will need to remove the head is if you've spun a bearing shell around within the big-end in the rod.
This stretches the rod's big-end, and the rod will need to be replaced, which must be done from the top.
Smile
Contact Details:
07732 822546
Posted 23rd Feb 2011 at 19:34
ben306
Ahh thanks, well the way my luck has been going at the minute, its probably spun a shell bearing then Sad
Will get the sump off next week and see if we can spot anything. It will be like a new motor by the time its done haha
3 sisters circuit
Few laps at Blyton
Posted 23rd Feb 2011 at 19:46
