Author Subject: Driveshaft balancing???
mattgti6phase2
As above
At low rpm I get driveshaft vibration with disappears as the revs pick up it doesn't normally bother me but when 4 up it's a wee bit worse and slightly annoying!
Someone said to me that my driveshaft requires balancing as in the same sense that wheels require balancing? I have never heard this before.
So I was just wondering if anyone here knows of this and if so where could I get it done
Thanks in advance
Matt
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 15th Feb 2011 at 04:41
Rich E Forum Admin
Nah, it will probably be a worn CV joint or slightly unbalanced wheels.
Can it be felt through the steering wheel or is it more through the shell?
Posted 15th Feb 2011 at 04:52
mattgti6phase2
It's not throughou the steering wheel. I get it through the gear stick as that moves back and forth slightly Crazy
5 x a 306 owner!
Posted 15th Feb 2011 at 05:01
inner cv joint Smile
Posted 15th Feb 2011 at 12:17
mattgti6phase2
Thankyou Big grin
5 x a 306 owner!
Posted 15th Feb 2011 at 16:45
Probably the bottom engine mount is worn too and that allows the bottom CV to wear more. You'll know when it gets really bad.
Posted 15th Feb 2011 at 17:26
I have this exact problem and have been told its a driveshaft. I'm wondering if it could be this now, perhaps I should just chuck it in a garage :S
Posted 15th Feb 2011 at 23:29
chris with a pug
I have never heard of a front wheel drive drive shaft being balanced. Rear wheel drive ones yeah but never on a front wheel drive car.
Posted 16th Feb 2011 at 02:38
They aren't balanced from the factory and don't need to be.
Posted 16th Feb 2011 at 03:49
mattgti6phase2
Just to add to this. Could a ball joint be causing the above? I have noticed it's now starting to knock in that area.
So am I right in thinking that the driveshaft wobble could be this balljoint?
Thanks in advance
5 x a 306 owner!
Posted 20th Feb 2011 at 05:58
Scrompy
Aka Quagmire83
No it will be the inner CV joint most likely the drivers side. You will need to replace the whole driveshaft as you cant buy seperate CV joints.
X-Box Live gamertag: Scrompy
PS3 tag: Scrompy
Posted 22nd Feb 2011 at 01:14
405gti6
Got the same on my 405. Slight shell/shifter rattle on lower revs. Will swap it on engine swap as its not so bad to drive! Doesnt help that much to have grp.n engine mounts hehe.
XU10J4RS powered 405 Big grin.
Posted 22nd Feb 2011 at 03:20
