Author Subject: Car current draw
Does anyone know the current draw of a normal running gti6?
I'm thinking of dropping to a 55A alternator to save some weight but dont want it to not be upto the job.
It will be for my track car so most un-necessary electrics will be removed, may eventually get a heated windscreen or electric heater blower to get rid of the heater matrix.
Any input will be appreciated. Smile
Posted 15th Feb 2011 at 03:06
rallyeash
if its any help here's my lightweight alternator on my 205 gti6. hung off the a/c mounts the a rose jointed adjuster i knocked up.
runs lights, and heated front screen. no heaters etc
side by side with old one
309 3dr K20 Type R
Posted 15th Feb 2011 at 03:15
cooper666
not sure but you wont burn out that cable i got you.
got some more already fitted with anderson plugs both ends ill drop it of one day
clio r27
ps3 id:cooperkloe
Posted 15th Feb 2011 at 03:17
Cheers Ash and Matt.
I'm intending to do something similar to your setup Ash, but i'll relocate the PAS pump to the a/c area, and rose joint the alternator to act as the tensioner where the alternator normally goes.
Is this the alternator your using?
Posted 15th Feb 2011 at 03:47
rallyeash
Yea mines a denso. I got took mine of a kubota diesel engine from work and cost me the grand total of 0...
309 3dr K20 Type R
Posted 15th Feb 2011 at 15:35
A bit of a thread revival but i have just got my nice lightweight alternator and there are some instructions saying that it needs a switched live for the 'T' connector.
You don't appear to have any wires going to this bit Ash, is there a reason or have you added some after that photo was taken?
My instructions say that they should both be on with the ignition switch, but one should go through a 1.2W bulb first.
Posted 19th Mar 2011 at 00:12
