Author Subject: spacers / pcd adaptors / load rating
gti-dan
Are spacers generally not recommended? What is the largest you can go? Just seen on a for sale thread for OZ alloys that you can get 20mm+ spacers direct from OZ. Does this mean they are fine to fit?
What about PCD adaptors - again are these ok?
Finally, I've not seen any info on load ratings of alloys when looking to buy? How do I know they are the correct load rating???
Posted 15th Feb 2011 at 01:10
With all the hassle of buying longer bolts, spacers and then wheels, is it not cheaper and better to get the right offset and PCD in the first place?
Longer bolts are'nt a problem, niether are 20mm spacers as long as they are hubcentric (and you must check that the fit correctly with the counter-bore on the wheel)
As for the PCD adaptors, contact the manufacturer to find the load rating, but to be honest, if they are properly designed for a car (and a Pug is'nt really that heavy) then they should be just fine.
Posted 15th Feb 2011 at 01:20
petey
I have OZ wheels that are Ford fitment so I have to run 21mm hubcentric spacers and longer bolts. It's not ideal, but as far as I'm aware it shouldn't be a problem. That said, I bought the lot second hand as a package for a pretty decent price - if this had not been the case and I was buying new I would just go for a direct fit wheel and not mess around with the spacers etc Thumbs up
High Boost Supercharged 306 GTI6
Alfa 147 GTA
Posted 15th Feb 2011 at 20:25
Paddy Power Turbo Banned!
where can i get a set of them hubcentric spacers and the longer bolts ?
TEAM(FIGHTIN IRISH)COMIN TO A PUB NEAR YOU !!!!
ps3 online name : butcherboy200
dyno print out : 185.4 at the flywheel
modern warfare 2 Wink
Posted 16th Feb 2011 at 07:24
rallyestyle
For what wheels?
Just Drive It
Posted 16th Feb 2011 at 15:57
matt.gti6
+1
Posted 16th Feb 2011 at 19:20
PUG306GTI
i want spacers for my cyclones!
Go RALLYE Go
Posted 16th Feb 2011 at 23:25
gti-dan
Why?
Posted 16th Feb 2011 at 23:52
PUG306GTI
why not? Thumbs up
Go RALLYE Go
Posted 17th Feb 2011 at 00:00
gti-dan
Are they going on a 6?
Posted 17th Feb 2011 at 00:02
PUG306GTI
nah im not that chav! going on a rallye LOL
sorry couldn't help myself
Go RALLYE Go
Posted 17th Feb 2011 at 00:07
For what wheels?
for a set a 17" compomotive 1776's ford fitment ! think its a 20 mil spacer ????
Posted 4th Mar 2011 at 17:39
If you're running 17's with 20mm spacers you might as well not bother and just drive around on the brake disks for all the handling and ride comfort you'll have Yes
Posted 5th Mar 2011 at 01:17
gti-dan
Out of interest, how will the spacers affect the ride comfort? Just the fact that you are moving the line of the wheel further from the hub? the same reason big spacers knacker the bearings?
Surely spacers have to be expected though. Apart from some wheels that fit without spacers, alloy wheel companys can't make every different wheel in every different fitment, there has to be an element of "making it fit" through the use of spacers etc???
Also why do people talk about the negative effect of 17's, I understand that they do make the ride quality worse, but is it any worse than 17s 18s 19s on a say a 3 series?
Posted 5th Mar 2011 at 01:46
If they're done properly (ie you have hubcentrics) then they shouldn't be so much of a problem, it's more than rather than having one lump of metal (ie wheel) to deal with, you've now got the spacer to deal with.
If they're not hubcentrics they're tricky to get central, if they're not central then they're likened to an unbalanced wheel. Not an issue if you're talking about a 3mm spacer, 20mm you might start to notice.
Most decent alloy companies do indeed do many different offsets, as it's just a case of casting them in a large negative (?) offset which they machine down to a lesser one. They don't do different molds for different offsets, no.
17's work on other cars because they're designed to take them, a car is designed as a whole, and only having an inch of rubber on a car on which the suspension was designed for much more doesn't really work No
Posted 5th Mar 2011 at 02:00
cheers owain i bought an escort with a set of these on it with new parada tyres really cheap just tought id find out before i went buyin spacers ill just sell them on for a bit a proffit n crush the car LOL its english and its red rotten !
Posted 5th Mar 2011 at 08:34
