The problem I have is that the blower is on at around half speed constantly, but will increace if you turn the dial up.
I have tried removing the control pannel to see if that is at fault and it made no change.
I have also checked the relays, and they are all ok (pulled it out and it stops, tried a known good one and still the same)
I've not checked the resistor thing (under the scuttle, if it has one even) as I dont have tools to access it atm.
Also had a look through the search function but that just seems to bring up non workign ones.
Anyone got any ideas to what could be a fault?
c_j_m
