Author Subject: Phase 3 engine loom to Phase 1 car
springs
Hi Guys.
when i built up my cab with a Phase 3 Gti-6 engine i fitted the phase 3 engine bay loom to the car. Now most things worked except a few key things in side the car. Now at this time the car would start and run with no problems etc.
I've now swapped the engine bay loom over to a working phase 1 loom and now the car doesn't turn over at all. Other things work as they should just not the engine.
I haven't had much time to look at it but i have confirmed that the starter motor isn't getting power.
I've noticed on the gti engine loom there is 2 or so more pins at the bottom of the connector where as the engine bay loom is missing them..
What i'm wondering is if the phase 3 Gti-6 engine loom is different to the phase 1 or 2 for the connector?
I really want to get the car sorted so need to know if i have to rewire it all or just get a new engine loom from a phase 1 or 2
Posted 11th Feb 2011 at 17:12
springs
anyone?
Posted 12th Feb 2011 at 03:18
So, it's a p1 car? Is it immobilised? As the p3 setup would lock via the transponder thing under the dash inside... No?
Posted 12th Feb 2011 at 03:56
I'd try the ecu first with an unlocked one. A p3 engine should plug straight into a p1 and fire assuming it's unlocked Unsure
Posted 12th Feb 2011 at 03:59
springs
The car is a phase 1. Engine loom is from a phase 3
The ECU is a Unlocked one from Rich W
Posted 12th Feb 2011 at 04:05
phase 3 loom wont fit in a phase 1 car the plugs and sensor clips are different ? A phase 3 engine will fit a phase 1 loom as long as you swap over the sensor connections Wink
Posted 12th Feb 2011 at 04:27
springs
the loom all fits fine like in any other 306, its just the car won't turn over because of some reason.
Posted 12th Feb 2011 at 04:31
aggyj17
Does it start if you arc the starter or bump start it? if so couldnt you run a new wire to the ignition
Posted 17th Feb 2011 at 20:03
springs
if i put +12v to the started and it tried to turn over.
Posted 17th Feb 2011 at 20:29
