Author Subject: Engine rebuild
cheesegrater
Hi all,
I've got my self a GTi6 and I'm planning on rebuilding the engine. Wheres the best place to buy parts? I'm thinking, valves, valve seals/guides, main bearings, big end bearings. Possibly get the cam's reground. Can anyone recommend places/rough prices?
Thanks,
Tom.
Posted 11th Feb 2011 at 03:20
You build engines then ?
You can't buy guides and unless you know what you doing I suggest you get someone who does to do it Wink
Posted 11th Feb 2011 at 03:25
cheesegrater
I know some who can do it Smile
Posted 11th Feb 2011 at 03:26
Pretty sure you can't buy guides but you shouldn't need them unless its a tapper ? or valves infact you could just strip it down and put it back together after a good clean with re lapped valves.
Should be good as new with all new gaskets and seals Smile
Posted 11th Feb 2011 at 03:31
Rich W on here can supply all the bearings - might as well have the crank ground and balanced Wink
cheesegrater
Ah ok brilliant cheers, I've removed the head and theres evidence of it having a cambelt crisis Razz
Engine turned over fine by hand with no evidence of hitting anything. But theres tipex on the pulleys, and small indents where the valves have hit the pistons. Is there anything else I should be checking?
Thanks for your help.
Posted 11th Feb 2011 at 03:35
yes you can get guides.
Posted 11th Feb 2011 at 03:50
cwspellowe
Aren't they standard pistons slightly pocketed anyway though?
Bye bye Sundance Kid Sad
Posted 11th Feb 2011 at 03:55
yeah, very very very tiiiiny valve relief's.
Posted 11th Feb 2011 at 04:02
