any RS head running decent cams don't run them either.
need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets.
displaying posts 26 to 41 of 41
Pages (2): 1 [2]
| Author | Subject: cams |
as mentioned earlier, the XU7 and XU10J4R don't have them.any RS head running decent cams don't run them either. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mad scientist
Junior User Location: Stoke Registered: 17 Nov 2008 Posts: 81 Status: Offline |
And remember, as said, you aren't designing an engine to last 200000 miles. You pay your money and take your chance! Simples! ________________________________________ 205 rally car with 2.2 hybrid 6 engine: phase 2 engine build underway. |
mad scientist
Back OT. If you want to decide if the efforts worth it, i'll take you out in the 205. I'm only down the road.________________________________________ 205 rally car with 2.2 hybrid 6 engine: phase 2 engine build underway. |
miles
The old follower wear issue is present even with Spray bars, on the 8v XU engine at least unless you use the right 76 Racing oil, we found with this from Follower wear every 6 race's, none was present after a year.As the cam has similar lift and design the same applies for this engine, Go solid and save allot of hassle too ________________________________________ 306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements, Full Workshop & Diagnostic Facilities New and Second parts, from Plugs to Turbo's We now also carry out Routine Servicing www.pugracing.com & FB Page, https://www.facebook.com/PugRacing Ebay; http://stores.ebay.co.uk/Pug-Racing-Shop 2012/2013/2014/2019 Class Winners at Gurston Down Speed Hillclimb & Joint overall, Class record too along the way, |
mattgti6phase2
Seasoned Pro Location: inside my 6 abusing the tarmac!! Registered: 16 Jul 2010 Posts: 2,371 Status: Offline |
________________________________________ Team Nile 6![]() Team: 40.2 MPG ![]() 5 x a 306 owner! currently abusing type r's in a town near you ™ ![]() I truely live for the 306 ® Build date: 29th October 1997 Wednesday's car midweek madness |
lotek
Seasoned Pro Location: Berkshire Registered: 04 Dec 2007 Posts: 6,107 Status: Offline |
fit a supercharger instead |
lotek wrote: fit a supercharger instead ![]() baaah. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
maddriver9
Regular Location: nr leek Registered: 12 Mar 2008 Posts: 341 Status: Offline |
miles says go solid lifters. is it expensive? and would that mean i could get bigger cams? for more power? ________________________________________ 178bhp 205gti6¼ mile in 14.2 |
maddriver9 wrote: miles says go solid lifters. is it expensive? and would that mean i could get bigger cams? for more power? CAT Cams were reasonable, I paid around £600 for Piper buckets and springs as I wanted stuff that would definitely match my Piper Cams, and did'nt want any nasty suprises. ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
mikeyskadoosh
Newbie Location: Llanelli Registered: 19 Feb 2011 Posts: 1 Status: Offline |
Post #35
i have 2.0 xsi and am looking for GTI 6 cams that are going cheap. if any1 has some please let me know. thnx |
Post #36
mikeyskadoosh wrote: i have 2.0 xsi and am looking for GTI 6 cams that are going cheap. if any1 has some please let me know. thnx Speak to Roland Rat / Ash he's got some. But you'll need quite a bit to make them work in your engine so you'd be better off buying a GTi6 engine, loom and ecu considering the going rate is only £350ish. ________________________________________ Nothing to see here |
maddriver9
Post #37
well got no work on at the mo as i,m a builder. so dropped my engine out, stripped it dwn to bare block. i was straight up to the local engine machiner and picking it up tomoz 2 pm .It will be bored out to 87mm ready for my omega hi-comp pistons.So i need to get some arp bolts .asap. Were can i get sum at right price?plus should i replace head bolts? I have't done in the past on me 8v engine but i know this engine is completly different so just checking. thanks people ________________________________________ 178bhp 205gti6¼ mile in 14.2 |
Post #38
maddriver9 wrote: well got no work on at the mo as i,m a builder. so dropped my engine out, stripped it dwn to bare block. i was straight up to the local engine machiner and picking it up tomoz 2 pm .It will be bored out to 87mm ready for my omega hi-comp pistons.So i need to get some arp bolts .asap. Were can i get sum at right price?plus should i replace head bolts? I have't done in the past on me 8v engine but i know this engine is completly different so just checking. thanks people Ditch the standard rods and get some steel ones (They will come with ARP bolts anyway) then you can make the most of your cams and pistons by bieng able to raise the RPM. And yes, you need new headbolts ________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
maddriver9
Post #39
well are't standard rods ok? to certain levels. have you sold yours? if so how cum? an to be honest dont think funds will allow it so who sells arp bolts at right price.________________________________________ 178bhp 205gti6¼ mile in 14.2 |
Post #40
Sold mine as it's going to be spending its (probably short) life at max RPM so I wanted the best I could afford. My PEC rods are sold yes, and they would be fine for anything other than endurance or circuit racing as the time spent at 9,000 RPM is minimal. Speak to Miles for ARP stuff, I'm sure he can point ypu in the right direction. And I don't see the point of fitting cams and race pistons if you limit your potential with stock rods. I'd wait till I had the money to do it properly. Just my tuppence worth though.________________________________________ R H Davey Welding Supplies. I sell new and used welding equipment in the Hampshire area. I take on welding jobs in the evenings, ally casting repairs are one of my specialities but I can weld pretty much anything. PM me with your requirements.Some of my services: (See my for sale threads) Engine mount/chassis repair Solid Beam Mounts BACK IN PRODUCTION Harness bars |
maddriver9
Post #41
miles says he cant get arp bolts at a good price cus he aint a dealer any know were else sells them?________________________________________ 178bhp 205gti6¼ mile in 14.2 |
Pages (2): 1 [2]
