displaying posts 101 to 125 of 172
Pages (7): first .. 4 [5] 6 .. last
Author Subject: Rallye stage rally car.
eddy_gti6
Post #101
Nice manifold you have there looks like the one I have but without the cat. Good progress mate Thumbs up
Posted 19th Jan 2014 at 22:13
Phil white
Post #102
devere wrote:
clen666 wrote:
Was this satchshift made for the 306 or has it been modified to fit?
Its not modified in any way. It is exactly as made, and fits the 306. The only thing is that it doesn't have a lift up reverse mechanism. Hence the agricultural lever attached to it to work the lift up reverse cable! Although that was only bolted on so is removed from the gear lever now.
I think I actually stole that off our garden rotavator!
What version was it if you don't mind me asking? 106 or 205? I'm sure they're different.
Posted 19th Jan 2014 at 22:22
devere
Post #103
Well I bought it for a 306. I would imagine it's similar to the 205 version. It is the same as the one in the Dixon race car thread.
I would imagine a 106 version is very different. If its the same as the kam racing site then the 106 version is a direct fit to the 106 tunnel etc.
Posted 20th Jan 2014 at 18:43
pugheaven
Post #104
Did Ross have the satchshift off you mate?
Posted 20th Jan 2014 at 18:47
devere
Post #105
It's still sat in my garage. I've been too busy trying to put the car together and working to sort things out as yet. I forget PM's sometimes so if so they're not being ignored just slip my mind. Once I've broken the back of my engine and box being in and sorted il sort things out.
Posted 20th Jan 2014 at 19:09
Phil white
Post #106
Cheers, I presumed you'd just bought one off kam and found it fitted. Dont think I'll risk bodging a 205 one on without skilled assistance.
Posted 20th Jan 2014 at 21:18
devere
Post #107
No to be fair I hadn't seen they sold them til quite a while after I got mine. And they don't stock a 306 one anyway. I got this direct off Colin and told him it was for a 306 etc. And he sorted it out for me.
Posted 21st Jan 2014 at 12:35
devere
Post #108
Well I had a reasonably productive day by my recent standards.
I now have the engine and box fully in. Subframe on. Struts, hubs and wishbones all on. Obviously brakes etc too.
I re installed my standard gear lever and linkage setup. Reason being I couldn't be bothered to waste any more time on the damn cable setup to be honest. Id rather be able to get the car running, and no everything is going to work as it should.
With this gearbox anyway, the forward and back movement is greatly reduced anyway, and from the initial feel of things it wouldn't want to be any shorter. So bear in mind this is with a totally standard gear stick and then I made up some rose jointed links to go to the box. I have taken one back off now, but all seems to work nicely. So im pretty happy with how its coming together, and also knowing I can use bits I know il get to work!
Pictures of today so far.
And in case anyone notices from that last picture, I wont be heat wrapping the manifold. When I bought it I was warned off it by the guy who makes them, as he said that it will shorten the life of it, due to it making the surface 'crystalise' as he put it. So making sure I get my moneys worth I shall just leave it be!
I may be tempted to get my throttle bodies on it later.. But we shall see.
Posted 26th Jan 2014 at 19:33
Post #109
Good work mate, keep it up Smile
Why are you reshelling anyway? (excuse me if its written earlier in the thread)
Posted 28th Jan 2014 at 09:39
devere
Post #110
Well to be honest it's mainly a case of wanting to simplify everything and start with a fresh car.
When the chance of a far stiffer and stronger shell came up I thought it was worth having a go with. It's got a far better cage than before too. That's another main reason. The car is pretty quick. So if it all goes wrong, I want a fighting chance of walking away!
I'm hoping that even with the big cage, I can get the car pretty light. And put as few bits on it as possible to keep the weight down! I never weighed my previous one, but I'd like to hope that even with more roll cage this one can be lighter than before.
Posted 28th Jan 2014 at 15:43
devere
Post #111
Didn't get a chance to do a great deal this weekend. Just chilling with my boy and watching some football mainly!
I did have a chance to start checking out if my seats will fit ok without to much modifying to my side mounts. looks like about 4 new holes drilled, and all should be good.
Not necessarily exactly where they will go. But I think its pretty close. I will probably lower my side down another hole and it will be good.
Am extremely pleased with how the gear shifting feels, even tho ive just been playing with it stationary so far!
Posted 2nd Feb 2014 at 21:29
devere
Post #112
Well this is the next step for the weekend. Fitting the new radiator. A nice height to get a nice bit of clearance for my airbox over the top.
Posted 6th Feb 2014 at 18:23
Carl Chambers
Post #113
what rad is that?
Carl Chambers
email; pugnacious.peugeot@yahoo.co.uk
C.M.CHAMBERS CARS
Peugeot Specialist
Tel; 01379 586101 after 6.30 or 07889 082466 anytime.
pugsport-racing.co.uk
Posted 6th Feb 2014 at 21:08
prt
Post #114
Why you use VTS phase 1 rack? What is the difference to GTI rack?
puGit Rallye Team
Posted 7th Feb 2014 at 14:52
midlife
Post #115
Less turns lock to lockThumbs up
Cool
Team 330™Cool
Team "no front end or engine"
Posted 7th Feb 2014 at 15:52
prt
Post #116
thx, midlife, men learns whole life Smile
puGit Rallye Team
Posted 7th Feb 2014 at 16:17
devere
Post #117
Its a shorter 205 rad. Its about 50mm thick too.
The standard height 306 rad was abou an inch and a half too high to fit my airbox above, now that I have the new inlet manifold.
This gives me lots of spare room now. Means I can make a better channel for the air to get into the airbox.
Posted 7th Feb 2014 at 16:35
Post #118
What's the rads capacity compared to standard?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 7th Feb 2014 at 17:06
Carl Chambers
Post #119
yeah I have got the same problem with my intake now as got a maxi airbox which is why I asked.
is it an off the shelf item? if so where from?
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 7th Feb 2014 at 19:51
pete_rallye
Post #120
looks like one of these- http://www.ebay.co.uk/itm/ALUMINUM-ALLOY-RADIATOR-FOR-PEUGEOT-205-1-6-1-9-GTI-1-8-DIESEL-1983-1997-/251342409319?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3A205&hash=item3a852cce67
Lap of the 'ring
Posted 7th Feb 2014 at 20:46
prt
Post #121
ori rad for maxi is 32cm high, 42mm thick and 69cm long. So it is exact as is in 205 1.9 gti. Except hose inlet, it's streight in maxi and curved in 205.
puGit Rallye Team
Posted 7th Feb 2014 at 23:18
devere
Post #122
Well not a lot has progressed too far recently. Getting a chance to do anything on my car, rather than running around after the girlfriend seems hard at the moment!
Anyway, I think I got my expansion tank plumbing sorted, the power steering pump officially in place, and the radiator should now be plumbed in too. Just need to add a few jubilee clips in the right places now!
The convenient length of the XSi top hose, with a certain amount each end cut off was perfect for my top hose. The BBM one wasn't long enough But that came in use elsewhere!
Modified the standard bottom rad hose to accommodate a different 90 degree bend to the radiator.
The expansion tank mounted in the appropriate place, and the hose into the engine in place also. Again, just needing hose clips to secure everything together.
I also managed to finally get my airbox to fit, with the satchell trumpets. Ended up being a proper pain I the arse though...
Im sure hopefully some time I will manage to get a whole day on the car, and not get interrupted to fix horseboxes and other cars!
Posted 23rd Feb 2014 at 21:20
Post #123
Nice update. Smile
Posted 23rd Feb 2014 at 21:37
eddy_gti6
Post #124
Any info on the coil leads you are running? Need to find some before I fit my omex what runs same coil set up you have
Clicky: [url =http://www.306gti6.com]click here[/url] remove the space between [url &amp; =
Posted 23rd Feb 2014 at 21:46
devere
Post #125
Good question...!
It was a long while ago I bought them, and to be honest I cant remember what they are off! I think I remember reading that leads off a corsa fit tho...? But I could be totally wrong. Sorry I cant be more help on that one, but if someone else sees this, im sure they will kno.w
Posted 23rd Feb 2014 at 22:03
