| Author | Subject: Excessive rear brake pad wear. 2 months! |
declfc
Junior User Location: Yeovil Registered: 01 Mar 2005 Posts: 81 Status: Offline |
Hi, I have a 98 306 GTi, Just before Christmas I replaced my rear brake pads and discs as the pads had worn down to the discs! But now the rear passangers side has worn the pads right down again! Nothing left! I made sure the piston was wound right back in when i replaced the pads? Cant work out why my pads have worn so quickly, just on one side? Help please! |
footah212
Senior User Location: Paisley Registered: 16 Sep 2010 Posts: 861 Status: Offline |
Mayby need to look at the caliper to see if the sliders are goosed.If the sliders are jammed then this would hold the pad against the disc causing the wear you describe. i am no expert though. ________________________________________ Phase 2 Blaze GTi6PS3 - Black Ops 2 Engine crane for hire Renfrewshire |
seized handbrake lever on that caliper.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
barry.rs
Seasoned Pro Location: South West Registered: 03 Apr 2003 Posts: 7,389 Status: Offline |
Could it be a sticking rear brake bias valve. |
not really, that would affect both brakes, and tends to give lower rear braking pressure meaning the discs go rusty and the front brakes work harder.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
gilesy
Seasoned Pro Location: Greenwich - in that London Registered: 03 Apr 2006 Posts: 5,133 Status: Offline |
Was it both pads on one side or just the outer? |
tvrfan007
Seasoned Pro Location: In the garage Registered: 29 May 2005 Posts: 3,488 Status: Offline |
Sticky piston. I had this and it killed a set of pads in 3 days once. heh.Red rubber grease FTW. ________________________________________ I'm Si btw![]() Night Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
