displaying posts 1 to 25 of 47
Author Subject: new changes to mot 1st january 2012
pugs16
There are to be some changes to the MOT test from 1st January 2012 which are being introduced in response to European Commission Directive 2010/48/EU of the 5th July 2010 and which will effect those with aftermarket HID headlights and remapped ECUs:
4.1.4 Compliance with requirements:
(a) Lamp, emitted colour, position or intensity not in accordance with the requirements
(Cool Products on lens or light source which obviously reduce light intensity or change emitted colour
© Light source and lamp not compatible
4.1.5. Levelling devices (where mandatory):
(a) Device not operating.
(Cool Manual device cannot be operated from driver’s seat.
4.1.6 Headlamp cleaning device (where mandatory):
For anyone with a remap, section 6.1.9 may be relevant.
6.1.9 Engine performance:
(a) Control unit illegal modified.
(Cool Illegal engine modification.
(by 'illegal', it is assumed that they mean changed/programmed differently from OEM specifications)
There will also be a new check on the general condition of the wiring:
4.11. Electrical wiring
(a) Wiring insecure or not adequately secured.
(Cool Wiring deteriorated.
© Damaged or deteriorated insulation
and on the function of airbag and seat belt pre-tensioner systems:
7.1.4. Safety belt Pre-tensioners:
Pre-tensioner obviously missing or not suitable with the vehicle.
7.1.5. Airbag:
(a) Airbags obviously missing or not suitable with the vehicle.
(Cool Airbag obviously non-operative.
7.1.6. SRS Systems:
SRS MIL indicates any kind of failure of the system.
Some of the above won't be popular with some around here I know, but VOSA have confirmed that the necessary changes to the MOT test schedule will be introduced and from 1st January 2012 vehicles that fall foul of the new requirements will fail the test.
Posted 7th Feb 2011 at 00:48
pugs16
sent to me from a friend, may affect some people on here Sad
Posted 7th Feb 2011 at 00:51
lotek
what a load of f*cking shite!! so no more modifications basicaly
Posted 7th Feb 2011 at 00:52
pugs16
nope Sad i didnt think it would take long to catch on to the hid situation....but aftermarket ecu/remapping Dry
Posted 7th Feb 2011 at 00:54
Yes and no, there was a thread on this before. Fair enough airbags have to work if fitted etc, wiring not secured are kinda common sense.
However - ECU remapped? How the hell is the crappy garage down the road to my work going to be able to tell if I've modified my map? Clearly they're not. Wouldn't surprise me if this is more for the solder-in-line resistor type chip.
Posted 7th Feb 2011 at 00:56
smegal
I'm sure this was dismissed as bullshit.
Ex SC-6
Now in a Megane R26
Posted 7th Feb 2011 at 00:57
smithers
Previous Thread
1997 Black GTi6
smithers205 at hotmail.com
Posted 7th Feb 2011 at 00:58
smegal
I've just read the rules here. The ECU gets a Visual inspection, I guess it is targeting piggyback devices and resisters.
The headlights rules are already in place.
Ex SC-6
Now in a Megane R26
Posted 7th Feb 2011 at 01:04
allesclar
bullshit i re-call. if this does happen then f*ck doing MOT's properly, i will just get ones made up and done for £50.
enough of all this EU shit.
does this mean i would have to get rid of the s/c or is it only after the changes are implemented.
although im sure you could just swap over ECU maps prior to MOT and just revert back after?
Team allesclar ®
Posted 7th Feb 2011 at 01:06
binkagti
what about people running different ecu, eg efi for my turbo
TEAM Supercharged Rallye
Posted 7th Feb 2011 at 01:18
Exactly as people have mentioned, some random fitter at a garage is not going to know a standard ECU from a different one - they're simply looking for stupid resistors wired in and piggyback stuff.
Garages do not have the equipment to check if your car has been remapped or not.
Posted 7th Feb 2011 at 01:27
rich_w
Have these changes actually been adopted and are they going to be enforced for domestic (not commercial) vehicles?
The document referred to 'European Commission Directive 2010/48/EU of the 5th July 2010' is only recommendations!
They need to make re-mapping / modifications etc illegal before it can be enforced through the MOT test.
Contact Details:
07732 822546
Posted 7th Feb 2011 at 01:38
mechanical_repairs
Hmm first I have heard of this and a lot of it seems hard to enforce, how are we as testers if this is true meant to know what each car has a specific ecu etc, I think someone is pulling peoples legs.
Carl
Posted 7th Feb 2011 at 01:51
smegal
You have made a really good point it states "illegal" modification.
There are plenty of illegal modifications, HID's are currently for example.
Ex SC-6
Now in a Megane R26
Rich E Forum Admin
No, it's a directive and the UK has to comply...
quote:
1. Member States shall bring into force the laws, regulations and administrative provisions necessary to comply with this Directive by 31 December 2011 at the latest, with the exception of the provisions of paragraph 3 of Annex II,which shall apply as of 31 December 2013. They shall forthwith inform the Commission thereof
Until the relevant statutory instrument goes before Parliament and the Lords for passage into law it's just guess work as to how the UK is going to comply with this.
It's likely that VOSA will publicise the changes to the test as soon as procedures are agreed so we'll have to wait until then for a definite answer.
It's marked as a visual inspection so best guess at the moment is they will look for external signs of tampering on the ECU and for obvious modification to the ECU loom, so piggy back ECU's and ECU's that have had an access hole to the map chip cut into them will be almost guaranteed to fail.
VOSA have said they don't foresee the extra requirements adding much, if any, time to the current test as most of the new requirements are within the tester's view at some point during current test. It's only the ECU one that they've said needs further thought.
It may be the case that these ECU rules will only apply to type approvals after a certain date, or the Lords may argue that they aren't applicable in the UK at all... We'll just have to wait and see what happens.
Posted 7th Feb 2011 at 02:17
v6saloon
basically that would mean no more modding is allowed as most serious mods, superchargers, turbo kits, engine conversions etc require an aftermarket ecu or a repap of the origonal, never going to happen in my oppinion, too much of a knock on effect.
205 mi16
405 Mi16x4 restoration project
406 v6 saloon track car project/daily driver
508 Hdi
Posted 7th Feb 2011 at 02:02
jcooper776
HID's are now illegal? Shock
When did this happen?
Had my MOT in october with them on and it passed fine.
Sold my GTI-6 now riding in a Scooby
James
Posted 7th Feb 2011 at 02:26
Rich E Forum Admin
HID retrofits have always been a legal grey area; technically illegal but no clear method of enforcement. These new requirements will provide a method of enforcement.
Posted 7th Feb 2011 at 02:29
allesclar
im glad HID's are illegal, they are a damn pain.
Team allesclar ®
Posted 7th Feb 2011 at 02:28
Rich E Forum Admin
It will be interesting to see if the police are told to enforce this at the roadside as without roadside enforcement it will just be another thing that people swap off for the MOT, such as decats.
Posted 7th Feb 2011 at 02:34
allesclar
but is it not illegal to drive a petrol car without a cat, so by looking underneath they can blatantly see a decat and no cat?
or is it all on the emissions?
Team allesclar ®
Posted 7th Feb 2011 at 02:37
Rich E Forum Admin
Yeah, it's emissions. VOSA do roadside emissions tests sometimes but their enforcement team is relatively small.
It would break the type approval though, as it had to be sold with the converter fitted.
Posted 7th Feb 2011 at 02:43
Decats are not illegal, but will probably cause you to fail on emissions.
Same as HIDs - they're not illegal per se, but if they leave your lights incorrectly aligned and impossible to realign, that's a fail.
clen666
I f*cking hate the EU
Team 'unintentional rat look'
Posted 7th Feb 2011 at 02:48
I wouldn't fret, in two years' time everyone will've forgotten all about this and it won't have made any difference to anyone.
Posted 7th Feb 2011 at 02:49
