On the way to work this morning managed to drive through a sodding great puddle, and shortly after that, the Stop light came on. Had just arrived at work so pulled over and shut her off. When I restarted and put the ignition to stage 2 (before start) there was continuous clicking from the relay box on the fans. Left it for a few hours to dry out and when I tried again, the relays had stopped clicking on stage 2 ignition but the fan (only got drivers side working due to an existing pro
would come on and off sporadically. When the brown plug is pulled, the clicking returns and the fan spins v slowly... Dried out the relays and gave em a squirt of wd40, and still the same. 4 hours later, even less stop light, but now when the brown plug is pulled, the relays dont click at all, and now i've got no fans! The Stop light is only on very dimly if at all. I suspect waters in the control unit and thats whats screwing everything up, but my main question is should i drive the thing home?
ribberz
