Author Subject: Crankshaft seal help
woody.
Hi,
I think my crankshaft seal on the drivers side maybe leaking and have read its quite likely the seal might have perished.
Can anyone tell me what part it is from the exploded diagram below:
Am I right in thinking its label 20? Its definately on the drivers side too.
Woody
Posted 6th Feb 2011 at 19:31
Rich E Forum Admin
No, it's part 5 (0326 22).
Posted 6th Feb 2011 at 19:48
woody.
Lovely cheers rich
Posted 6th Feb 2011 at 20:46
woody.
How hard is it to change one rich?
Posted 6th Feb 2011 at 20:52
Rich E Forum Admin
The seal its self is relatively easy. If you have trouble getting it out then you can screw a couple of small self tapping screws into it and use them to pull it out.
Remember that the cambelt needs to come off to get to it though. If it's only a slight leak then I'd consider leaving it until the cambelt is next due.
Obviously if it's a big leak you'd want to tackle it without delay though.
Posted 6th Feb 2011 at 21:24
woody.
Ahh that's not good. Cambelt was done ~7000miles ago and the only mechanic I trust is Carl LOL
How long do you reckon it will take? I'm guessing it's going to be £200 minimum?
Posted 6th Feb 2011 at 22:58
Teshboi1988
what is 20? a rubber seal?
phase 3 Hatchback V reg 5Door GTi6
Posted 19th Feb 2013 at 09:24
It's an o'ring, held in place by the pulley once it's bolted on. Don't forget about it when you reassemble.
Posted 19th Feb 2013 at 09:30
Will need new belt fitting tooThumbs up
Posted 19th Feb 2013 at 09:40
Teshboi1988
f**k. when i reassembled i did not see an old one come off. what wood happen if you dont fit one.. and by the looks off it its behind the cog that runs the oil pump right...
if so easiest way to get to it?. because im thinking sump off
Posted 19th Feb 2013 at 12:04
Oil will leak out from behind the belt drive pulley. This is probably the leak you are seeing if the o'ring wasn't installed, but you can get to it by removing the casting that the crankshaft oil seal sits in I think.
Posted 19th Feb 2013 at 16:28
bas_306gti
on early type engines the o-ring nr. 20 was not used, i doubt it's absolutely necessary
Posted 19th Feb 2013 at 17:47
woody.
Thread from the dead LOL to clarify, I had a new seal and belt fitted and all is running well 2 years on Thumbs up
Posted 20th Feb 2013 at 02:20
LOL didn't notice date of orig posting!!!!Whistle
Posted 20th Feb 2013 at 10:18
