Author Subject: Lowering seats
maverickbeer
Ive had a search but cant find anything. I want my drivers seat lower. Ive used the lever on the right of the seat near the door but I still want it lower. Is there any other leavers im missing? My head isnt far from the roof and I arent that tall. It might be because Ive been driving round in my caddy which is on its arse.
A little bit sideways
Posted 3rd Feb 2011 at 18:01
matt.gti6
Unfortunately thats as low as they go - my main grumble with the '6 is how high the driving position is.
Posted 3rd Feb 2011 at 18:26
pugthis Banned!
Is it not possible to lower it at all!?
It must be get the grinder out maybe?
Jeremy clarkson
''This is the most unreliable car ever made. In fact, if you've got a more unreliable one, write to us at: Actually I've Got a Peugeot, BBC Top Gear, London…''
Posted 3rd Feb 2011 at 19:53
And remove what? Only way to lower the seats is to attach it directly to some weld-in seat bars and then you'll lose the ability to slide them.
Posted 3rd Feb 2011 at 20:18
get some other seats that have less height on the bottom is my only guess
Posted 3rd Feb 2011 at 20:39
Bucket seats with runners are as high as the standard ones, I have them myself Yes
Posted 3rd Feb 2011 at 20:40
You need to remove the box section under the seats then weld in some new rails to take the seats I would also re strengthen the floor pan or use a cage as the box section is kinda there for a reason
Wink
Posted 3rd Feb 2011 at 21:54
maverickbeer
Bummer, was hoping it would be a bit more simple than grinding and welding. Suppose I will just have to put up with falling out the window when im railing it. Ha. Im sure I will get used to it again, its not been on the road since last june so forgot what it was like.
Posted 3rd Feb 2011 at 22:26
darzmat
im 6'2" and i dont find the driving potion too high all, wouldnt mind moving the rails back a bit tho for more leg room
Posted 4th Feb 2011 at 01:47
lewisdmz
I was also hoping there was an easy way to do this. I read in the 205 the seats have spacers between them and the rails which you can remove to get an extra inch or so.
Posted 4th Feb 2011 at 02:28
Na, no such luck. I think technically it's easier to just remove a couple of vertebrae from your spine.
Posted 4th Feb 2011 at 12:21
matt.gti6
This is true, they are around 10 or 15mm thick. The seating position in the 205 was much better IMO (even without removing the spacers), and the seats really pinched you in nicely. It was a shock when I left my 205 GTi for the 306 GTi6! I'm half tempted to fit my old 205 seats into the '6 sometimes! LOL
Posted 4th Feb 2011 at 14:38
pugthis Banned!
Grind and weld it will work no doubt,dont see why it wouldnt
Jeremy clarkson
Posted 4th Feb 2011 at 16:39
