Author Subject: tapper
broggy Banned!
my engine sounds perfect from cold but tapps when it warms up? it has had 2 oil changes and now runs on 10/40w semi still exactily the same???
j.d
Posted 3rd Feb 2011 at 17:28
rallyeash
tapping from the top or bottom of the engine? video would help, does it increase with revs?
309 3dr K20 Type R
Posted 3rd Feb 2011 at 17:39
broggy Banned!
top and gets bit louder
j.d
Posted 3rd Feb 2011 at 18:09
rallyeash
sewing machine type sound?
309 3dr K20 Type R
Posted 3rd Feb 2011 at 19:19
broggy Banned!
ummm sort of mate yeah but it is alot more metalic sounding
j.d
Posted 3rd Feb 2011 at 19:24
rallyeash
hard to say without hearing it, take a video of it and post it up. ideally one when cold and one when hot.
normally a "tapper" will always tap
309 3dr K20 Type R
Posted 3rd Feb 2011 at 21:52
1.6306
hi, i had a similar problem not to long ago, my freind is a mechanic and all he did was pop the head of to reveal something call taper heads, he said over a long time they need lubricating and slight adjustment, in asda or you local autoparts store they will have stuff u put straight into your oil which lubricates these parts and also other parts or have a mechanic adjust the tapper heads, then you should have a quiter engine,
does your enginge sound like a 1992 ford fiesta?
Posted 3rd Feb 2011 at 22:29
glenn_addo
This is a tapper video I found on ebay is it as bad as that?
I thought mine might be a tapper this morning but I put a video up and the general opinion seems to be that it isnt from the video.
Heres my thread about it
Posted 3rd Feb 2011 at 22:36
kiwibrick
Had this happen to my 6 not long after I got it, was quiet when cold but small tapping sound when warm/hot, turned out to be a loose spark plug.
ph2 GTi-6
Posted 4th Feb 2011 at 05:17
broggy Banned!
rite from cold its perfect. leave it to warm up at idle it starts to faintly tap and as the temp gauge rises it clearly gets louder i think i have to take the head off its really buggin me now..
j.d
Posted 5th Feb 2011 at 17:48
Rich E Forum Admin
That sounds like it could be the beginnings of a bottom end failure to me.
A bent valve / worn guide tap would be present from cold. It could be a lifter I suppose, but it's rare for them to cause problems.
Having said that, these engines are louder generally from cold as most engines are so are you sure it's not masking the tap when cold?
Posted 5th Feb 2011 at 19:04
broggy Banned!
i cant hear it tap from cold mate and a mechanic has lookd at it and told me its a liffter but like you say they are very rare to go>>>
j.d
Posted 5th Feb 2011 at 19:49
