Author Subject: Coolant temp sensor query
:: blade ::
I did a search but couldnt find anything.
Just wondering what this sensor actually does? My car has been running lumpy on and off for a few month now and felt down on power, so been changing bits here there and everywhere. So ive just changed the green temp sensor on the pug and everything seems fine now seems to have its power back and run fine. So any info welcome Big grin
Black Ph1 XSi-6
161.8BHP (Getting Better!!!!)
Posted 3rd Feb 2011 at 04:55
Rich E Forum Admin
It's used by the ECU to enrich the mixture when the engine is cold, effectively making an electronic version of a choke.
If the sensor is giving a false high temp reading then no enrichment will take place when the engine is cold and with a false low temp reading it will continue mixture enrichment after the engine has warmed up which is what it was doing on your car.
Posted 3rd Feb 2011 at 22:21
:: blade ::
ahh right, i see Smile, thanks for that, now to sus out why the car stinks on idle Smile
Black Ph1 XSi-6
Posted 3rd Feb 2011 at 22:23
Rich E Forum Admin
Stinks of what? Petrol?
Posted 3rd Feb 2011 at 22:32
:: blade ::
yea fuel, got a feeling the lambda is on its way out, but not sure
Black Ph1 XSi-6
Posted 3rd Feb 2011 at 22:33
Rich E Forum Admin
Will most likely be the rubber fuel lines in the engine bay. They are probably all cracked inside and seeping fuel.
Posted 3rd Feb 2011 at 22:36
:: blade ::
them pipe are pretty much new tho, will get them checked tho
cheers Smile
Black Ph1 XSi-6
Posted 3rd Feb 2011 at 22:38
Told you it would be the coolant temp sensor Razz Laugh
Posted 4th Feb 2011 at 20:19
:: blade ::
:p ur just too good, want to diagnose the other faults Big grin :p
Black Ph1 XSi-6
Posted 4th Feb 2011 at 20:57
bennn
It could have well killed off your lambda and wont have been doing you're cat any good if its been overfueling for a while.
Cherry Red 306 HDI
Posted 4th Feb 2011 at 21:02
