Author Subject: Head
rthorne
Hi can anybody give me any advice on the best way to change the cylinder head+gasket as iv never done this before and heard it can be tricky
Thanks, rowan
Moonstone gti6
Posted 2nd Feb 2011 at 01:08
Thanks, rowan
To be honest, if you've never done it before, and your not 100% sure what you are doing, leave it to someone that is. No offence intended, but if you haven't got the knowledge, you could well end up doing more harm than good, plus you will need an extensive set of tools to be able to complete the task.
Stan.
Posted 2nd Feb 2011 at 03:50
manthos
true +1
how are you stan?
Team SUPERCHARGED
Old Project thread
Posted 2nd Feb 2011 at 03:52
manthos wrote:
true +1
how are you stan?
I am all good mate, I trust your keeping well. Smile
Posted 2nd Feb 2011 at 12:59
stan
it's "you're"
Whistle Laugh
yep you'll need an arsenal of tools that's for sure. i thought everyone who owns a 306 has a decent set now though considering how often they break?
Posted 2nd Feb 2011 at 14:47
rthorne
What size socket do I need to remove the head , what to use to get the old gasket off without scratching the block ?
Moonstone gti6
Posted 2nd Feb 2011 at 16:08
you need a rail of large torx sockets really cos there's torx heads everywhere so makes more sense having them all. the gasket's a 3-layer one and will just lift off easily, no scraping etc
Posted 2nd Feb 2011 at 16:12
rthorne
Then put new gasket on and head on then torque it down
Moonstone gti6
Posted 2nd Feb 2011 at 19:27
not before getting the head checked for tolerance and possibly skimmed. and obviously then the engine needs timing up and new cambelt etc fitted
i would get someone to help you first time round, it'll be daunting if you haven't done it before
are you fairly handy with spanners?
Posted 2nd Feb 2011 at 19:36
rthorne
The head wil be fine it's coming from Richard at pugplus so won't need testing should be fine
And yeah quite handy with a spanner it seems quite easy to do but jus wanted a few tips on how not to go wrong
Moonstone gti6
Posted 2nd Feb 2011 at 21:45
always needs checking unless its already been checked.
Posted 2nd Feb 2011 at 22:24
rthorne
How much does this usually cost to be tested ?
Moonstone gti6
Posted 2nd Feb 2011 at 23:24
ryangti6
Definitly get it checked, its false economy not to especially with a head you never saw running.
Places vary on cost quite a lot when I rang around. The best price I got was £70 iirc and that was to skim and pressure test a head, it'll be less if you dont need a skim.
Ryan
Posted 2nd Feb 2011 at 23:50
rthorne
Spoke to the guy who I'm buying it off he wil make sure everything is tip-top as it is stil i'n the car + running if this is the case wil it be ok to put i'n mine ?
Moonstone gti6
Posted 3rd Feb 2011 at 00:00
you never know.
Posted 3rd Feb 2011 at 00:02
ryangti6
Why take the chance? When you are doing such a big job it's something you only want to do once.
I would never fit one I havnt personally heard isnt a tapper myself but at least have an engineer check it over, then you know it's all good.
Ryan
Posted 3rd Feb 2011 at 00:07
You will, need new stretch bolts, something to clean the block deck (scotchbrite and diesel work well), a decent torque wrench for doing the head up, spanners/sockets/allen keys for the inlet and exhaust manifolds. And some 6mm and 8mm drill bits to time up the head before you put it back on. Plus you will then need a cambelt tension checking tool. Basicly more kit than its worth buying to do the job once as I've just rattled off the best part of £300 worth without head, bolts and gasket.
Posted 3rd Feb 2011 at 00:11
rthorne
If I take it to a head specialist would they check it and put it all i'n and time it up if so how much would that be ?
Moonstone gti6
Posted 3rd Feb 2011 at 00:31
Ring one and get a quote, but expect it to be around the £3-400 mark.
Posted 3rd Feb 2011 at 01:17
