Author Subject: Clutch fork arm pin
cwspellowe
Any tips on removing it? i've had mole grips on it and been tugging (snigger) all day, it's refusing to budge and i'm getting VERY p*ssed off now.
Bye bye Sundance Kid Sad
Posted 1st Feb 2011 at 23:13
bash it (carefully) the other way to free it off.
if no luck chop the arm off.
Posted 1st Feb 2011 at 23:47
jonnie205
bend arm up then attack it when box on floor
Posted 2nd Feb 2011 at 00:47
simonjames
Soak it in WD40 and tap it back and fore
MY EBAY ITEMS
07943066306
Posted 2nd Feb 2011 at 00:51
cwspellowe
Rather not destroy the arm, would be more expense to replace it.
Might try tapping it in a bit first then
Posted 2nd Feb 2011 at 01:26
simonjames
I got a spare arm if you do damage it
MY EBAY ITEMS
07943066306
Posted 2nd Feb 2011 at 01:34
ryangti6
I usually tap the side but at an angle that will make it move forward using a chisel or old screw driver, its a bit awkward to get much angle but it usually loosens them enough to pull them out after a few taps.
I did have one that just wouldnt come loose. I had to get it all the way out with the above method as it was that tight so I'd be reluctant to hit it in any further, 9/10 it will work but sods law it wont and you be left with less of the pin to play with.
Ryan
Posted 2nd Feb 2011 at 01:41
heliosphan
You can easily bend the arm up enough to remove the 'box without damaging it at all. Mine went no further than 30 degrees and the 'box came free. Then just gently bent it back with no lasting damage. f*ck spending hours on that pin, I'd rather gouge my eyes out with rusty spoons. 2 mins and job's a good 'un LOL
Posted 2nd Feb 2011 at 01:59
tvrfan007
This, worked on my particular box. Smile
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 20th Feb 2011 at 17:16
he`s right you know!!
get it bent upwards, if you do decide to replace it its around £35 from pug.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 20th Feb 2011 at 20:52
