| Author | Subject: Sump plug size? Oil temp sensor related |
flynn_
Junior User Location: Faketown Registered: 29 Jan 2011 Posts: 59 Status: Offline |
Hi, I want to setup an oil temperature gauge for my pug as the stock one isn't that accurate. I heard that the sump plug is either 14 x 1.50 or 14 x 1.25. The website that I ordered the gauge from had some adapters but only in 14x 1.50 so thats the one that I ordered. I called up pug and they said it was 14 x 1.25 so where can I get that sized adapter from? Thanks. |
rallyeash
pretty sure its 14 x1.25.im actually looking for the exact same thing so i can wire up my SPA oil temp and water temp gauge. merlin motorsport only list m14 x 1.5 ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
flynn_
Just looked on Demon Tweaks and they've only got 14x1.50 or 12x1.25 as well My oil change is overdue so I want to sort it fastish |
rallyeash
been on there also, surely somone must make them? at worst could buy the M14x1.50 and get a M14x1.25 dye to change the thread. ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
I wouldn't put it in the sump plug, just remove the stock sender.IMO there's no need though, they are accurate enough to give an indication that something is awry, you never need to be that precise with temps. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
rallyeash
ill be fitting one in the top sensor hole in thermostat housing for water temp and the front sump bung for the oil temp. mines on a 205 rallye so no temp gauges atall.________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
ablister
Senior User Location: fife Registered: 30 Oct 2005 Posts: 522 Status: Offline |
when i used one, i used a durite oil temp gauge which had a 1/8" nptf sender so needed a 14x1.25 adaptor from demon-tweeks, change 'sender thread' to 1/8 npt and 'male thread' to m14x1.25________________________________________ 306 rallye, Richard Longman enginerc10gt |
rallyeash
tidy, just what im after. will order two now![]() ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
flynn_
ablister wrote: when i used one, i used a durite oil temp gauge which had a 1/8" nptf sender so needed a 14x1.25 adaptor from demon-tweeks, change 'sender thread' to 1/8 npt and 'male thread' to m14x1.25 I could have sworn they didn't do an adapter for it I've just put the details of my sensor and required adapter and its come up with one My sensor is an M10 thread so different from yours but they still have an adapter it seems. Going to order one now, thanks for the link. Edit; is there any particular reason to go for short or long? |
I bought the Demon Tweeks one and it does still go in, just takes a bit of grunt ![]() Don't bust your sump though. ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
flynn_
Hi owain. Did you get the long one or the short one? And why was there a problem with getting it to go into the sump thread? It is 14 x 1.25, that is the right thread so it should fit in easily :s |
No idea why it was tight but it was, and it leaks unless you get it all the way in. I got This one, M14 and 1/8NPT. ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
rallyeash
i ordered the short one________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
flynn_
owain wrote: No idea why it was tight but it was, and it leaks unless you get it all the way in. I got This one, M14 and 1/8NPT. I need the M10 one bud. The washer should stop any leaks you get, perhaps it was not seated correctly? rallyeash wrote: i ordered the short one Is that the same length as the pug one? |
flynn_
Just found out the source of the confusion:http://www.demon-tweeks.co.uk/Motorsport/Gauges_Instrumentation/Gauge_Pipes_Adaptors/LMA_Oil_Temperature_Sump_Plug_Adaptor/1773/1844 http://www.demon-tweeks.co.uk/Performance/Gauges_Dial_Kits/Fittings_Accessories/LMA_Gauge_Sender_Unit_Adaptors/812/1847 There two different sodding pages! No wonder I couldn't find the M14 x 1.25 sensor the first time round! Wonder what that is all about :S |
