Author Subject: gearbox mount, easy to fit?
xsi_lew
Hello all,
i think i might upgrade my gearbox mount at some point and was just wondering how easy it is? it looks pretty simple from the FAQ..
Posted 28th Jan 2011 at 16:37
i was thinking about giving this a shot as well, the faq does make it look easy, but im just worried about the jacking up the engine bit and the potential for serious f-ups
how much is a gearbox mount anyway? i should probably look into that too
Posted 28th Jan 2011 at 16:47
xsi_lew
for a fast road one its about £50 on spoox. i think the best thing to do in terms of jacking the engine is to used a block of wood to support the engine and the gear box sump.
Posted 28th Jan 2011 at 17:20
jbradders
You only have to jack the gearbox up just to hold the weight,then 3 bolts.
Posted 28th Jan 2011 at 17:27
easy as anything
Posted 28th Jan 2011 at 17:46
oecken
yes as above very easy, always look at Mile's off here's uprated mounts, i had the Gearbox and lower engine mount Thumbs up just make sure the one you buy already has the new mount pressed in to save ballache, and its an easy switch.
Posted 28th Jan 2011 at 18:02
is there much point getting a uprated one? exactly how much more vibration do you get?, at the moment my car shakes like $£$£ when i acclerate , seems to happen most in like 6th and 4th at high speed and about 3-4k
the gear knob nods a lot when the shaking is going on aswell, i assume this mount is the problem?
Posted 28th Jan 2011 at 18:06
oecken
the mount, if completly knackered may be the cause vibration but not so specifically in those gears.. as far as vibrations, i had updated mounts Group N, as well as uprated gear linkages and solid rear beam mounts and there was a lot of vibration. when i first started the engine i litterally though WTF IS GOING ON, but got used to it, the acceleration and general response was improved somewhat if not more so by placebo more than anything LOL
Posted 28th Jan 2011 at 18:24
gota6again
Driveshaft fella Thumbs up
Posted 28th Jan 2011 at 18:19
really?... is this going to be expensive? Sad
Posted 28th Jan 2011 at 18:25
gota6again
I got mine done about a year ago but there was loads of other work done at the same time so couldn't tell you if it was cheap or not.
Posted 28th Jan 2011 at 18:34
i just had a good search after you said driveshafts and it looks like youre right
Looks like this will be more expensive than i hoped... tax soon aswell
Posted 28th Jan 2011 at 18:35
ravemercer
Parts are fairly cheap changing is quite straight forward about 1 ½ - 2 hr. Drivers sides the worst those two poxy 11mm nuts ratchet spanners a gods send, if you have the tools you would be surprised how easy it is.
Posted 29th Jan 2011 at 04:16
