Author Subject: stalling, rough idleing
1.6306
hi,
lateley my car has started idling rough and stalling when coming to a stop when cold and hot, ive cleaned the iacv there was no change, i bought a after market iac valve bu that made th car rev at roughly 11000rpm. the valve is constantly open should it be like that? also if anyone has other sugestions about what the cause could be that would be great.
thanks in advance
1.6306 has attached the following image:
Posted 23rd Jan 2011 at 05:59
smegal
What speed does it idle at?
Mine idles at 1080 RPM according to peugeot planet.
Ex SC-6
Now in a Megane R26
Posted 23rd Jan 2011 at 06:19
stegti6luvr
Replace the ICV with a genuine part, Also check for air leaks in the intake Wink
Posted 23rd Jan 2011 at 06:48
ryangti6
What car are you actually talking about? I'm guessing a 1.6?
If so that ICV pictured wont be for your car, yours should use the same magnetti marelli one as on a gti6, that bosch one is for an S16.
Ryan
Posted 23rd Jan 2011 at 16:08
bob
How much are the genuine ICV's?
Posted 24th Jan 2011 at 03:18
smegal
About £60 for a GTI-6
Ex SC-6
Now in a Megane R26
Posted 24th Jan 2011 at 06:08
jakeypoo
Sounds very similar to the MAP sensor also! Mine would judder quite a bit on idle and then the revs would drop so low when coming to a stop that it would stall! £12 for a used good MAP sensor, sorted!
Posted 24th Jan 2011 at 11:55
davedgti6
Impressive getting your car to idle at 11,000 rpm LOL , even Rich W's car only rev's to 8,500, just put the proper icv on and it should idle ok.
Posted 24th Jan 2011 at 23:30
1.6306
hi thanks for the replys,the part i put on the piture is the correct one for the phase2 306 1.6 glx, when i said 11,000rpm i meant 1,100rpm lol! i had a qoute of peugoet for the iacv for £159.00, where would i find the map sensor is that the one that controls the buterly on the throtle body or have i got the wrong part?
thanks
Posted 25th Jan 2011 at 06:11
