Author Subject: 15mm bolt on specers
bellcp306td
I m looking at some 15mm “bolt on” spacers so I can fit some 206 gti wheels to the 306. I am looking for reassurance. Are they fine for track use?
I am looking at H&R or Eibach ones.
Thanks
Where did the road go!
Posted 23rd Jan 2011 at 03:43
ksung17
ive used 20mm on rear chris with 60mm tapered bolts with washer from taper to flat and there fine, but dont know about tracking.
Posted 23rd Jan 2011 at 03:50
dragoon
I don't think 15mm can be bolt on (30mm and thicker can)
You'll need hub-centric ones, in 4*108 with a 65.1mm centre. You will need longer bolts.
I personally prefer not using spacers but when used correctly they should be fine Smile
Team Wheelwhore
Team Limited Edition
Astor 306 Francorchamps RIP
Virtual Blue 208 GTi
quote:
I Love this place. So many illiterate deluded fool's acting 'ard . . . and so many literate intelligent people to rip them apart and knock them back down again . . . ahh Cool
Christ think of the weight gain though.... the 206 rims aren't light for track work...
chrisd306
Id say your ok for track use with the spacers as ive ran with 20mm spacer for a year, but why would you want to run with the 17's on, have you got big brakes?
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 23rd Jan 2011 at 03:56
bellcp306td
I have read some threds for use with longer bolt ones. Its the bolt on then bolt your wheel to them.
As for weight the tsw 17's that are on the car right now are 19kg where the 206 ones are 14kg. I need 16" rims because of the brembos.
Also the car is an every day car to and if I put Speedline Turini’s on I think Chavs will be killing them selfs to steel them!
Anyway change of plan I will just get hubsentric with longer bolts. People are ok with them and have no problems. I was just thinking to use the bolt on ones I would be able to use the original pug nuts. The track thing with the 206 wheels is a worst case I hope to get some track only wheels with r888’s on. What do people recommend am I on the ball with the speedlines?
The car is looking good Ksung
Posted 23rd Jan 2011 at 23:41
bellcp306td
Its the 16" ones people call them Nimrods but there not called that. and yes i have Clio192 Brembos on the front
Posted 23rd Jan 2011 at 23:46
bellcp306td
and yes they dont do 15mm bolt on ones. i was been Insane again.
Posted 24th Jan 2011 at 21:33
nikozinio
..with 12 mm spacers ,Atlantis 206 RC wheels
nikozinio has attached the following image:
Peugeot Club BULGARIA
Posted 29th Jan 2011 at 00:09
nikozinio
Posted 29th Jan 2011 at 00:13
bellcp306td
looks nice
Posted 22nd Feb 2011 at 15:15
jardo
They are called Nimrods. But Nimrods are the wheels that came on 206CC's and the like, they are the wrong offset for a 306 and really require spacers otherwise you get wheel wobble at speed.
Ourogans are the wheels that came on 406's and have an offset that is right for 306's.
They aren't light at all, I've only kept mine for daily duty. If you are going for a performance track wheel try some C5 steelies.
Heres mine with no spacers -
Also, heres a set of 15mm bolt on hubcentric spacer - http://cgi.ebay.co.uk/15MM-4x108-HUBCENTRIC-SPACER-M12-x-1-25-CITROEN-PEUGEOT-/390180862298?pt=LH_DefaultDomain_3&hash=item5ad897795a#ht_735wt_905
Posted 23rd Feb 2011 at 03:20
bobdylan_55
that looks nice ^^^
309 GTi6-T
Posted 23rd Feb 2011 at 03:21
bellcp306td
Looks mint!
Posted 23rd Feb 2011 at 15:10
bellcp306td
Ok i sold the nimrods and got me some Speedlines!
Nice!
Posted 13th Apr 2011 at 17:21
