Author Subject: Numberplate lights - PHOTO
musclebeach
Both my lamps are out, After looking at the fuse FAQ i can't find a relevant fuse. Any ideas? It's a phase 1, many thanks
VW Golf GT TDI 115, 100k nooooooooooooooooooooo!
Posted 22nd Jan 2011 at 17:49
dont they run on th e side lights fuse?
so if theyre all working its not the fuse
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 22nd Jan 2011 at 17:52
musclebeach
Thanks Andy, yes i guess so. Yes the sidelights do work.....hmm looks like a wiring problem then. The wires will hopefully run inside the boot near the lock i guess
Posted 22nd Jan 2011 at 17:59
simgti6
the numberplate lights loom plugs in the rear passenger light (white plug)
Posted 22nd Jan 2011 at 18:46
dan_s16
They are plugged into the passenger side rear light, make sure the connector hasn't fallen out etc
Edit: damn too slow Doh
Posted 22nd Jan 2011 at 18:47
change the bulbs first, its a possibility that they have both blown
when did you last notice them both working?
maybe one has been gone a while and you didnt notice,and now the other has gone it mnakes it seem like its a problem.
ive had both headlamp bulbs go at once before, after scratching my head for a few hours i changed the bulbs and they worked
Posted 22nd Jan 2011 at 19:49
musclebeach
Done it, yes you could say it was a wiring issue.....
Turns out the white wire had been wrapped around the green one which had been stripped just enough to get to bare wire, and it had come off....
Also the yellow wire's attached to the green one!
What's going on there? Wiring into a Live? Haven't a clue how electrics work tbh!
Posted 22nd Jan 2011 at 22:37
