Team ex "manstone" - "THATS TO LOW!!"..."I KNOW!"
Team defeat - bring on the *06! :/
| Author | Subject: S16 front brakes |
noaki
Senior User Location: \"sunny\" Bournemouth Registered: 05 Apr 2009 Posts: 506 Status: Offline |
are gti6 frnt brakes better if so will they fit an S16 ________________________________________ Team ex "manstone" - "THATS TO LOW!!"..."I KNOW!"![]() Team defeat - bring on the *06! :/ |
Rich E
Yes and yes.________________________________________ Rich |
mr swampy s16
**BAD SELLER** Location: out and about Registered: 22 Oct 2003 Posts: 10,550 Status: Offline |
Never had a problem with my s16 brakes.And always found i could brake as late and hard as a gti6. I was running pagid rs 4 2 blue pads and braided lines mind. |
GTI6 brakes weigh a lot more, but cost a lot more both in discs and pads.I would get some uprated pads in the S16 calipers first, and if that's not enough then some 4-pots on the 266mm discs from a 307. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
stepup
Junior User Location: Basingstoke Registered: 02 Jul 2008 Posts: 55 Status: Offline |
I'm fitting '6 brakes to mine, they weigh loads more than the s16 ones and cost alot more. But I've heard the feel is much better, and my original ones are on the way out, so I'm giving them a try. ________________________________________ owain wrote: Twisties are for those with balls, top speed is for those with tiny little penises. SCIENTIFIC FACT. |
ballys16
Regular Location: Godollo Registered: 05 Mar 2009 Posts: 247 Status: Offline |
I wonder why an p1 XSI setup stops an XSI 3.4 meters sooner than p1 S16s stop the S16?Surely not the ~20kgs? S16 pads are also bigger, right? ________________________________________ XSi 8V -> S16 |
naah, same brakes.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
ballys16
welshpug! wrote: naah, same brakes. Sure? Cant seem to find ThermoQuiet for the XSI but only for the S16. ________________________________________ XSi 8V -> S16 |
yup, all the same part numbers, check servicebox if you don't believe me ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
dragoon
Seasoned Pro Location: Ghent - Belgium Registered: 30 Dec 2008 Posts: 1,071 Status: Offline |
and there are brembo max for the 266mm setup ________________________________________ Team WheelwhoreTeam Limited Edition Astor 306 Francorchamps RIP Virtual Blue 208 GTi quote: I this place. So many illiterate deluded fool's acting 'ard . . . and so many literate intelligent people to rip them apart and knock them back down again . . . ahh ![]() |
ballys16
welshpug! wrote: yup, all the same part numbers, check servicebox if you don't believe me ![]() Finally found the cause for my mistake: we put on the Xsara 266 brakes. The pads are mighty big as well as the "pot" ________________________________________ XSi 8V -> S16 |
