thanks
No smoke No Poke
| Author | Subject: ph2 -ph3 headlights? |
samthornton1990
Newbie Location: Harrogate Registered: 19 Jan 2011 Posts: 11 Status: Offline |
Quite new to pugs (ex dub man) can you just fit the phase 3 headlights into a phase 2? Same connectors etcthanks ________________________________________ No smoke No Poke |
bennn
Seasoned Pro Location: Shrewsbury Registered: 05 Sep 2008 Posts: 2,705 Status: Offline |
Yes. You will need to swap the headlight adjusters over though 30 second job and you will realise this when fitting.________________________________________ Cherry Red 306 HDIChampionship White Integra DC5 Type R |
samthornton1990
sweet, cheers bud, what's different about the adjusters?________________________________________ No smoke No Poke |
bennn
samthornton1990 wrote: sweet, cheers bud, what's different about the adjusters? The connector, you wont be able to plug yours into the phase 3 adjuster. ________________________________________ Cherry Red 306 HDIChampionship White Integra DC5 Type R |
Mine went straight in ....?! No connector issues.________________________________________ Nothing to see here |
yours wasn't a Phase 3 though, nor was the car they came from ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Later adjusters are black phase2 adjusters and brown I'm sure that both phase 2 and 3 run pairs of H7 bulbs but someone has said that phase 2s are single H4 ???? ?????????? |
gtomi-6
Seasoned Pro Location: southampton Registered: 16 Jan 2009 Posts: 1,136 Status: Offline |
on the nile i brought a set of crystals off of miles , all of the clips had broken on one side of my standard phase 2 ones. as i only wanted crystals to black mask i had to take the lights apart and swapped bits from the old to the new to make a perfect set. no issues with plugs the guts where the same. and i think they all run 2 h7's________________________________________ ph3 gti-6 china blue- mint conditionph2 gti-6 nile blue K.I.A dec 2010 |
bigbadbowen wrote: Later adjusters are black phase2 adjusters and brown I'm sure that both phase 2 and 3 run pairs of H7 bulbs but someone has said that phase 2s are single H4 ???? ?????????? that's the lower spec cars. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
