Author Subject: Sluggish car and MPG query
:: blade ::
reet all got yet another prop with my car, filled the tank a few weeks ago and done 317miles which ive worked out for it to be around 29mpg, what should these engines get??
another thing is its been driving fine for the 2 weeks up until today on my way home from work, the car felt sluggish, say if you plant your foot it would take a few seconds for it to kick in then it would feel fine? not sure what this could be really
hope you can help
cheers
Black Ph1 XSi-6
161.8BHP (Getting Better!!!!)
Posted 17th Jan 2011 at 21:51
Had this with mine and it turned out to be the coolant temp sensor?
The green one on the thermostat housing Yes
Posted 19th Jan 2011 at 18:54
:: blade ::
Cool cheers, will get that checked Smile
Black Ph1 XSi-6
Posted 19th Jan 2011 at 19:11
anth
Just sounds like its over fueling so that should sort it. 29 mpg isn't that far from the norm though.
Posted 19th Jan 2011 at 19:15
:: blade ::
Been told it stinks on idle quite bad aswell, i have got in the past around 36-39mpg from it
Black Ph1 XSi-6
Posted 19th Jan 2011 at 19:24
sharvey44
maybe MAP sensor? does it hesitate slightly when you accelerate?
Ph2.5 Nile - Slowly trying to de-East London it and restore to former glory...
Built on the 9 Febuary 1999 - Tuesday's car..is full of pace? Wink
Currently looking slightly molested due to some c*nt trying to get into it.. Sad
According to the forum Social Worker, because I work in IT, I am socially retarted..
Posted 19th Jan 2011 at 19:32
:: blade ::
A little bit, the map sensor has been changed with a fully working one, i could change it back i spose and see if that has an effect
Black Ph1 XSi-6
Posted 19th Jan 2011 at 19:40
sharvey44
did you reset the ECU after?
Posted 19th Jan 2011 at 20:14
:: blade ::
Yea Smile
Black Ph1 XSi-6
Posted 19th Jan 2011 at 21:06
rallyeash
coolant sensor could be the issue. worth changing for the cost of them
309 3dr K20 Type R
Posted 19th Jan 2011 at 21:09
:: blade ::
How much are they??
Black Ph1 XSi-6
Posted 19th Jan 2011 at 21:42
bennn
bout a tenner from pug i think.
Cherry Red 306 HDI
Posted 19th Jan 2011 at 22:28
smegal
When I am next home you can bring it round if you want and I'll run a diag on it.
The coolant sensors are about £10 from ECP or about £20 from peugeot.
Ex SC-6
Now in a Megane R26
Posted 19th Jan 2011 at 22:34
:: blade ::
That would be cool that smegal, just give me a pm when ur back Smile will get a coolant temp sensor sometime next week Smile
Black Ph1 XSi-6
Posted 19th Jan 2011 at 23:09
swiftyboi006
29mpg quite lucky if you ask me. I take it the cars standard?
Black p3 Love
Posted 26th Jan 2011 at 01:26
cwspellowe
It's an XSI - 6 hybrid iirc. I'd have imagined it would be slightly better than a gti6 on fuel.
Lambda's another shout too by the way, mine was sluggish as hell unless on wide open throttle. Replaced the lambda and its been fine
Bye bye Sundance Kid Sad
Posted 26th Jan 2011 at 01:36
:: blade ::
Yea xsi body but everything else is a gti, tbh the mpg is bad compared to what it used to be i have had around 36mpg. Will get the lambda checked asap. But atm need to get a clutch sorted as mine has started to slip now. But it was fine on full thottle its just getting up to it its sluggish,
And yea Pretty much standard apart from magnex cat back and a k&n air filter (which will soon be replaced with a standard airbox with replacement filter)
Black Ph1 XSi-6
Posted 26th Jan 2011 at 02:26
