displaying posts 1 to 25 of 30
Author Subject: Custom Inlet for the turbo conversion
pugheaven
Posted 16th Jan 2011 at 23:02
pugheaven
Iv had this fully polished now and looks the tits, lets just hope it works ok!!
Posted 16th Jan 2011 at 23:03
ryangti6
Looks good, makes more sense in my mind to have the intake the other side of the bay on turbo'd cars.
The pug1off yellow 205 is the same and I think it looks loads better than pipes going everywhere
Ryan
Posted 16th Jan 2011 at 23:35
pugheaven
It was made by someone on the escort cosworth forum, it added 15bhp and 36 lbs ft torque compared to the standard one just hopes it works well on mine!
Hopefully less lag as it shortens the boost pipe by over a meter!
Havent seen the pug1off manifold?
Got to relocate powerstearing using the s16 mounts and relocate the washer bottle also.
Posted 16th Jan 2011 at 23:57
pugheaven
Posted 17th Jan 2011 at 00:02
pugheaven
I should really do a project thread but no time atm!
Posted 17th Jan 2011 at 00:09
fozzy_255
You should definitely make a project thread. Would love to see how its done.
Posted 17th Jan 2011 at 01:44
allanallen
On a gti6?
Facebook
Posted 17th Jan 2011 at 02:06
pugheaven
No on a escort cosworth, hasn't Breen fitted to mine yet as it's not built! He put it on a flow test bed before and after the work was carried out and the flow is better than what it was.
I hope it will be worth while but only time will tell!
I will probably have it mapped with a standard manifold then mapped again with this one and see what difference it will make.
Posted 17th Jan 2011 at 02:35
pugheaven
Didn't realise that a few ppl are planning on doing turbo conversions and have had a few pms regarding the inlet, can get them made for £200 when u supply a standard one and polished for £100.
I appreciate that it is not proven yet but if your intrested let me know!
Can also get exhaust manifolds made by maniflow Same as mine for around the £600 figure in stainless steel! That's what they quoted me when I asked a while ago!
Dare to be different and give the sc boys something to compete against!
Posted 17th Jan 2011 at 03:42
smegal
Looks like it'll be a good conversion, my only concern is the length of pipe before the turbo where all the branches are conencted.
Ex SC-6
Now in a Megane R26
Posted 17th Jan 2011 at 04:49
ryangti6
It looks very well made as does his exhaust manifold, I havnt seen many turbo'd ones but none use the same exhaust or inlet manifold as his.
I've got a pic that I took at pugfest to give you an idea
Car porn Imo Love
Ryan
Posted 17th Jan 2011 at 06:11
allesclar
wow, apart from the yellow and e-tech brace, that is sexy as Smile
Team allesclar ®
Posted 17th Jan 2011 at 06:26
pugheaven
The pipe needs to be that that long to locate the turbo round the side of the engine, the turbo sits about half inch away from the head!
Every gti6 turbo conversion iv seen has the same ish design?
Tom on here with the gold gti6 turbo, the 309 turbo project, dp engineerings manifold!
No problem with the pipe length maybe the pic doesn't show it too well!
Posted 17th Jan 2011 at 10:46
pugheaven
By the look of that pic my pipe is shorter after the collector to the turbo flange than his?
Is he running 8 injectors, 2 fuel rails as I can't see clearly on my phone!
Posted 17th Jan 2011 at 10:52
binkagti
Hi mate, yeah he runs an 8 injector setup, small for normal running and then large when on boost.
Have to say your manifold looks better than mine mate, not sure why colin never thought of doing it that way, looks so much better and should be less laggy.
TEAM Supercharged Rallye
Posted 17th Jan 2011 at 13:41
pugheaven
Colin didn't have anything to do with the inlet but he wants one made for his some time in the future! Not too expensive to have done either.
You could have one made for yours?
Posted 17th Jan 2011 at 13:55
binkagti
I know he had nothing to do with yours mate, what i meant was not sure why he did not do it for my car the way your one is done, would have made more sense.
Posted 17th Jan 2011 at 17:07
pugheaven
I get ya mate, dont think he knows anyone that could do it this way and have it flow tested to see if there is and gain!
I was in afghan when I had it done, Colin helped with the technical side as I couldn't see an inlet as I was away and the matey needed some info!
What I Ment was Colin didn't put me in contact with this dude!
As mine won't be on the road for a while I would be willing to let u borrow it and see what difference it will make to yours!!
You would probably need a remap tho as it will shorten ur boost pipe snd lower the intake temp!
Posted 17th Jan 2011 at 17:33
binkagti
Hmmm ok mate, will have a think, trouble is my intercooler pipe work is only on one side, not both, so would have to try another intercooler, will def want to see wht you think of it when done, might be persuaded to buy one.
Posted 17th Jan 2011 at 18:45
gtomi-6
matt got his made by an american company i believe
ph3 gti-6 china blue- mint condition
ph2 gti-6 nile blue K.I.A dec 2010
Posted 17th Jan 2011 at 20:10
smegal
The dp manifold doesn't have as long a collector pipe.
Ex SC-6
Now in a Megane R26
Posted 17th Jan 2011 at 20:14
pugheaven
No but each header pipe is longer still locates the turbo to the battery bay so over all got to be the same length as mine and everyone else that had done a turbo conversion
Posted 17th Jan 2011 at 20:16
pugheaven
Dont be worried anyway as it's my conversion if anyone should be worried it should be me and I'm not!
Thanks for your input!
The manifold has already been used on a car and was fine!
What about other turbo cars with the turbo further down the exhaust?
Posted 17th Jan 2011 at 20:25
smegal
To be fair it'll work fine, the longer the individual pipes the better (as the longer collector damps the pulses) but it is only marginal.
I'm excited to see how it performs. With the forged goodies it should make good power.
Ex SC-6
Now in a Megane R26
Posted 17th Jan 2011 at 21:06
