Author Subject: Boot Button stuck halfway
musclebeach
Well my boot button stuck in today so after some WD40 managed to get it free'd, but it only comes out half way!
The boot won't shut, removed the 8 torx bolts to get to the assembly and still can't get it pushing out more than half way, even gentle persuasion with the hammer wouldn't do it!
After looking, there's a rod that's attached to a spring which pushes on the button from the inside. There's also another rod leading to the drivers side of the car, i assume this is for the Central Locking
Any ideas?
VW Golf GT TDI 115, 100k nooooooooooooooooooooo!
Posted 15th Jan 2011 at 22:57
musclebeach
f*cking arsehole!! Turns out the whole push mechanism is french and very susceptible to dirt! We've now got the impossible task of getting a bent rod through a hole which doesn't want to move!
Fecking forum's been down all afternoon as well Roll eyes
Posted 15th Jan 2011 at 22:59
vernam616
Any ideas?
Have a better look, mine did this whilst it was icey/cold weather, i managed to get the button back out but the boot wudnt shut
Took the inside panel off and noticed a small metal rod was floating around, stuck it back into its holder and it was fine
Audi S3 Black Edition
musclebeach
f*cking thing's broke, the sliding mechanism has alot of grit in it i can't get to.
Needs a new one but it's a total PITA to fit!
Posted 16th Jan 2011 at 02:06
sport1901966
Mine occasionally sticks, locking and unlocking the car via the remote usually makes it pop back out
Posted 16th Jan 2011 at 02:20
musclebeach
Mine used to, then it went terminal!
Posted 16th Jan 2011 at 03:11
berger
Hmm mines started to do this.
Used some 3 in 1 with PTFE I got from Halfords and it seems a little better.
Whose the girl in your avatar?
Bang'in 7 gram rocks!
I have one gear, GO!
Posted 16th Jan 2011 at 22:05
musclebeach
Can't remember mate it's really old, think i got the pic from a smartpunk forum thread about hotties.
And mine's past that stage, the long bit of the button that slips back and forth in the housing is actually damaged so if it's pushed too far it spreads out and it's like trying to get a square peg in a round hole....Thank you though Smile
Posted 17th Jan 2011 at 04:47
