Author Subject: Boost hose
mcfc1987
I'm currently in the process of relocating my mechanical boost gauge. It's currently above the ashtray and is going to the A pillar. I therefore have to double the length of hose as ill still be using the same hole drilled into engine bay. My question is, will the added length of hose affect the performance of the gauge?
Posted 15th Jan 2011 at 01:00
mechanical_repairs
No it won't mate.
Carl
Posted 15th Jan 2011 at 01:28
mcfc1987
Cheers , would it be best to have the same diameter hose all the way through.
The hose i have to go on is larger than the existing hose, i was just going to connect the two together.
Posted 25th Jan 2011 at 22:09
chrisd306
what size of hose is it you need for the T piece at the manifold, a sim needing to order some for mine as moving gauge also
In my garage just now
& Audi Q5 S Line
AX stock rod & Saxo Stock rod
Posted 25th Jan 2011 at 22:17
mcfc1987
either 3 or 4mm i believe, on mine rich then reduced it to a smaller harder pipe to run it through the engine bay, I've got some more 4mm bore stuff to join onto it and run it through the interior.
don't know if doubling the bore size will affect the performance of the gauge though
Posted 25th Jan 2011 at 22:22
chrisd306
Shouldnt as your still getting same amount of pressure regardless of size of hose could be wrong like
& Audi Q5 S Line
Posted 25th Jan 2011 at 22:33
mcfc1987
Going to be sorting mine out at the weekend, if i can just change the bore size i will have 3 meters of unopened black samco hose with a 4mm bore you can have for cheap
Posted 26th Jan 2011 at 01:19
chrisd306
sounds good to me mate, pm me once you know whats left, just now im prettry sure ive got 2 bits of diffrent size hose stuck together as it was a bodge job to get it working lol
& Audi Q5 S Line
Posted 26th Jan 2011 at 01:40
mcfc1987
well i mistakenly ordered 2 lengths of 3 meters instead of 2 meters so i will probably have it spare, let me know if 4mm is good for you
Posted 26th Jan 2011 at 01:46
