Author Subject: removing cigarette lighter.
scott-thomas
hey guys, im new on here and couldnt find a thread anywhere. how do you go about removing the cigeratte lighter? ive got a phase 2 d'turbo and ther cigarette lighter needs replacing :S
s.millman
Posted 10th Jan 2011 at 17:25
bennn
You need to removed the dash panel, if you prise off the lower bit that covers the clock, remove the clock, remove the other 2 screws you see. Remove the radio and round the back of the panel there are 2 10mm nuts you need to unbolt, once you pull out the panel you just disconnect the lighter socket and remove it.
Cherry Red 306 HDI
Posted 10th Jan 2011 at 17:45
scott-thomas
i did this the other day but the lighter wouldnt come out :S do you just prise it off or something?
s.millman
Posted 10th Jan 2011 at 17:53
bennn
Think it pushes out. I cant really remember tbh it been 4 years since i did it!
Cherry Red 306 HDI
Posted 10th Jan 2011 at 17:59
scott-thomas
ok, thanks for your help Big grin
s.millman
Posted 10th Jan 2011 at 18:02
vernam616
IIRC there is a black bulb holder on the back of the lighter, so undone the dash panel as said above and remove the black bulb holder and it should slide out, you might even be able to do it by removing the clock only
Audi S3 Black Edition
Posted 10th Jan 2011 at 22:06
scott-thomas
so the bulb holder slides off? or is there a little screw?
s.millman
Posted 10th Jan 2011 at 22:43
