Author Subject: kangarooing help
bukosgti6
took my 6 out today and the power keeps cutting out then would come back a second or too later its geting worse seems to be when its warmed up ive had cg motors do a service and had lambda sensor changed on thursday any help guys please.
Posted 8th Jan 2011 at 23:29
Loose earth ??? checked the pos terminal on the battery ?
TPS could on its way out as well
Posted 8th Jan 2011 at 23:43
bukosgti6
ok tps strange it was unplugged for mths so plugged it back in throttle responce was better thought i would disconnect it today but it cut out and will not start put it back in and it started repeted this a few times but it wont run with tps disconected.
Posted 8th Jan 2011 at 23:52
bukosgti6
when i say power cuts out engine is still running light are on as well
Posted 8th Jan 2011 at 23:55
bukosgti6
looking on here could it be the map sensor
Posted 9th Jan 2011 at 00:40
bukosgti6
just unplugged my map sensor took it out for a drive and it seemed to pull a lot harder i take it the map is shagged
Posted 9th Jan 2011 at 01:34
If the engine is running at idle with the MAP sensor connected and then you unplug it, the car should cut out. If it doesn't, then you need a new MAP sensor...
Stan.
Posted 9th Jan 2011 at 19:02
bukosgti6
it did at first but seems fine now stan il get a map asap i was told the car wouldnt be any quicker with map unplugged and must be in my head.
Posted 10th Jan 2011 at 17:17
