Author Subject: Removing AC
gti-dan
I'd imagine this has been covered but search Is not bringing anything up. How much of a job is it to remove? Will prob ask a garage to do it. How much are the rallye aux belts and pulleys etc? Is there much else to strip other than the compressor?
Does it need anything doing to keep all the fans running properly? Cos I know how complicated the fan system is and it's all linked in with the AC system.
Posted 2nd Jan 2011 at 19:32
miles
It's easy, remove the pump and fit any normal XU10 non A/C belt set up, It's not just a Rallye fitment which a few people think, The engine was used in millions of Citroens and Pug's, The tensioners are quite cheap new from most motor factors
www.pugracing.com
Posted 3rd Jan 2011 at 01:04
gti-dan
Miles, would the existing tensioner not work? Is it not an auto tensioner on the ph3?
Posted 4th Jan 2011 at 20:42
ballardpaul
I tried a cheap fix by using the old tensioners with a slightly shorter belt to miss out the ac. Work for weeks at a time but would just snap randomly leaving me with no power steering, so just gave up trying and bought a non ac set up.
Nissan 350Z (300 BHP)
Posted 4th Jan 2011 at 20:55
gti-dan
How much did that set u back? What is different?is the non AC set up different to the rallye set up?
Posted 4th Jan 2011 at 20:58
ballardpaul
About £60 second hand a good two years ago now.
Nope there both the same, aslong as it's off the same engine it will work.
Posted 4th Jan 2011 at 21:03
gti-dan
So once I have the compressor out how much else is there to strip out? Is it easy to get at?
Posted 4th Jan 2011 at 23:57
Bit tight to get your hands down between bodywork and engAngry
You need to remove belt/air con pump/belt auto tensioner and IIRC one other rollerSmile
I've just bought a new tensioner for my Rallye,£27 from local motor factors.Smile
Belt was £8.74 from Motaquip.
You will then need one roller,and the adjusting screw for tensioning beltSmile
Pretty sure I've got a spare new adjusting screw in the garage I could sellWink
Posted 6th Jan 2011 at 03:35
Parts required circledWink
Number 4 is the one I've just bought from a motorfactors,much cheaper than PugSmile
If your local motor factors can't find it just show them the picture,mine could not find it listed for a 306,but found it easily looking through pics in the catalogue!Roll eyes
Would have thought the other roller should be available from them tooSmile
Posted 6th Jan 2011 at 04:08
ballardpaul
If Coskev don't have the tensioning bolt then drop me a pm as I def have 4 as you have to buy them in packs of 5 from peugeot.
Posted 6th Jan 2011 at 05:38
Sure mine came in a pack of two!Smile
Hence I've got a new one kicking about spareWink
Posted 8th Jan 2011 at 03:11
ballardpaul
Yeah I think they come in 5 from dealers but because they said they won't sell them to anybody else I had to buy all 5. £10 it set me back Doh
Posted 8th Jan 2011 at 03:14
